182
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. F_Mateo_Bratanić_aDzP
    Froyo Aug 20, 2019
    F_Mateo_Bratanić_aDzP , Aug 20, 2019 :
    I certainly will NOT fix issues. I paid Oneplus to do that when I bought the phone. It's their job to keep phones operational, not to slow them down with bad software updates. Owner of the phone is not required to be an expert in fixing and meddling with software. They should have left 3t at peace, without pushing Pie.
  2. S1566278154059
    Cupcake Aug 20, 2019
    m.parvage likes this.
  3. m.parvage
    Froyo Aug 20, 2019
  4. LPC Backlash
    LPC Backlash , Aug 20, 2019 :
    Hi all, I have had my Oneplus 3T for over 3 years now and all I can say is this phone is amazing. I have updated by OTA every time one becomes available and have not had a single problem with the handset at all.
    No issues with lag, or battery, I use as my work phone and personal and use it several hours per day making calls and light game playing and web browsing.
    I see a lot of negative comments but some basic tips, clear the cache once the update installed, battery will need to re calibrate so give a couple of days.
    All in all I would say this is the best handset I have ever owned and currently see no reason to upgrade due to still been fast and doing everything I want.
    Well done Oneplus, keep up the quality work.
  5. 9141789057
    9141789057 , Aug 20, 2019 :
    nope its not...i thought it would be sorted with this ...but still i have that caller id bug, notification slide and screen timeout problems
  6. Jannis Mitsalos
    Jannis Mitsalos , Aug 20, 2019 :
    My phone has no service and when you try to call it says disable flightmode if you wish to call, and when you look the flight mode is off, i have whiped cache and that didnt help, now i am sitting here with a usles company phone, just great...need fast help or fix. ps i tested the sim on another phone and i worked with full service.
  7. O1521668246656
    O1521668246656 , Aug 20, 2019 :
    DonHartnett
    Would you mind showing your battery usage at the end of your day with the full device usage showing?
    hey my screen on time is ~ 3 hours
    usage was before on oreo the same
    brightness is most of the times on 100% and I play the most of times games like clash royale or pokemon go so the phone is working. 80% of the day I use mobile data
  8. DonHartnett
    DonHartnett , Aug 20, 2019 :
    Thanks for that, what was your SOT usage? SOT = screen usage since last full charge?
  9. S1560483305681
    S1560483305681 , Aug 20, 2019 :
    thanks for recent update .
    I am observing problem after updating my phone .
    Three finger screen shot gesture is not working.
    who else have same problem please let me know.
  10. atulclassic
    Honeycomb Aug 20, 2019
    atulclassic , Aug 20, 2019 :
    yes, i am exactly saying that
    also, one liners are not enough to prove it too
    m.parvage and S1560483305681 like this.
  11. L1566304786446
    S1560483305681 likes this.
  12. O1521668246656
    ~3 hours
  13. ghostofcain
    Marshmallow Aug 20, 2019
    ghostofcain , Aug 20, 2019 :
    Ah millennials, I do wonder how you'd have faired back in the windows 3.1 days? Anyhow your phone should work just fine, with the OnePlus supplied software, its the crud YOU have installed on it that's causing issues. But hey if you don't want to improve YOUR experience just carry on as you are.
    Blue-agila, Auristic and r.hutton like this.
  14. G1566308216316
    G1566308216316 , Aug 20, 2019 :
    Hi everyone,
    Since the update a couple of days ago, I've been experiencing significant lags and slow performance.
    Switching between apps is now very frustrating because it lags for around 3 to 5 s. This is even worse when the charger is plugged in.
    Please let me know if anyone is experiencing this problem, and if there's a plan to fix these issues soon.
    Thanks!
  15. H1518548573026
    H1518548573026 , Aug 20, 2019 :
    I still have the heating issue. also the battery issue. any solution
  16. H1518548573026
    I was thinking my issues was with instant heat and rapid battery drain but now after going through all the comments I checked my camera and it's also not working. Does anyone have any solution. I need to fix these ASAP
  17. Topper_Gas
    Jelly Bean Aug 20, 2019
    Topper_Gas , Aug 20, 2019 :
    What apps have you got installed on your phone, are they solely those w supplied by OP and Google, if not, how can you be so sure it is OP fault and not the developer of some rogue app you've got installed, Google only this week removed a number of battery draining apps from the Google Play store.
    I've no issues with my OP3 but I've taken the trouble to ensure all my apps work satisfactory with the Pie build without excessive battery drain.
    Auristic and ghostofcain like this.
  18. F_Mateo_Bratanić_aDzP
    Froyo Aug 20, 2019
    I have not installed anything for months. I was not complaining of battery drainage, only on genersl slowness and especially inability to answer calls.
  19. Sadra_Imam
    Gingerbread Aug 20, 2019
    Sadra_Imam , Aug 20, 2019 :
    It's turned off by default and it has been disabled since forever. I never use that feature.
    The new phone app has serious issue and need alot of work to be as stable as older versions in OOS 5.0.8
  20. astralbee
    Ice Cream Sandwich Aug 20, 2019
    astralbee , Aug 20, 2019 :
    It's a three-year old phone. You're well out of any warranty period. During the warranty you possibly could have got them to fix it, even while most of us were happily sorting our own issues with a quick search of this forum or Google. But now, after 3 years, don't be so lazy and entitled. You're utterly wrong about 9.0.5 being broke and totally in a minority with your issues.
