182
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. Minesh_Bhagwan_Fiji
    Cupcake Aug 23, 2019
  2. AlbizzieOne+
    Donut Aug 23, 2019
    AlbizzieOne+ , Aug 23, 2019 :
    Hi guys,
    I finally solved the problem with the camera focus. I opened an RMA and Oneplus replaced my room module for free, even for my old OP3.
    GREAT OP!!!
    ghostofcain likes this.
  3. Jahin7
    Froyo Aug 23, 2019
    Jahin7 , Aug 23, 2019 :
    Google duo really heating up the device. Why this is happening in pie builds don't know.
  4. AndyRadikal
    Froyo Aug 23, 2019
    AndyRadikal , Aug 23, 2019 :
    Yes I figured it out too, duo makes the phone hot as hell , and is not the only app doing it .. in general even surfing the web no matter if use edge or chrome will make the phone unexpectedly hot .
    I think is something related to the network usage coz it become very hot only if I'm under mobile network connection. Plus mobile network is always draining a huge amount of battery compared to oreo
  5. Jahin7
    Froyo Aug 23, 2019
    yes ! I agreed. mobile standby drain is also a big issue in this build. Requesting OnePlus team to fix those issues.
  6. Tanshid_45
    Eclair Aug 23, 2019
    Tanshid_45 , Aug 23, 2019 :
    Even after this update I still have issues with my hotspot where I can't access internet through other devices, not just that, screen mirroring still doesn't work after 5 different versions of Android pie... please fix this
  7. Brian OBrien
    Gingerbread Aug 23, 2019
    Brian OBrien , Aug 23, 2019 :
    I connect my laptop to the web via the wifi hotspot of my OP3 for a minimum of 6 hour per day. It's working flawlessly for me - immediate connection and no dropouts.
  8. Tanshid_45
    Eclair Aug 23, 2019
    maybe it's perfectly working out for you but not in my case
  9. Rui Delgado
    Froyo Aug 23, 2019
    Rui Delgado , Aug 23, 2019 :
    So not a software issue. Or better, not a problem from this update. Try a clean flash.
    I use OP3 as a hotspot and, in the same way, connect my OP3 with any hotspot. Not a problem in both ways.
    Brian OBrien likes this.
  10. Tanshid_45
    Eclair Aug 23, 2019
    it is...phone was working fine untill Oreo soon after the pie update issue began
    simsekhasan likes this.
  11. Manan55555
    Eclair Aug 23, 2019
    Manan55555 , Aug 23, 2019 :
    Update is just slowing down my device I can't even see caller ID for 10 secs when i receive a call
    simsekhasan and 9390969044 like this.
  12. W1565978340747
    Donut Aug 23, 2019
    W1565978340747 , Aug 23, 2019 :
    come on bro plz [e]1f64f[/e] sort out this heating issue plz IAM suffering a lot it's not like this before
  13. W1565978340747
    Donut Aug 23, 2019
  14. nwhorizon
    Froyo Aug 23, 2019
  15. astralbee
    Ice Cream Sandwich Aug 23, 2019
    astralbee , Aug 23, 2019 :
    Rubbish. Until a couple of years ago, Oneplus phones were sold exclusively via this website. A majority - not a minority - of Oneplus users are likely to know about this forum.
    And I'm not a "millennial". I'm 44 years old and my Oneplus 3 works juuust great.
    I see you're asking the same question again but you won't get a different answer because the issue you have barely described isn't a known bug. Oneplus will not reply to you here because this is a user's forum. A forum 'for em'. I'm a user. We don't owe you anything, so be nice to us if you want help fixing your issue (which I've concluded you don't).
    Auristic, ghostofcain and Blue-agila like this.
  16. F_Mateo_Bratanić_aDzP
    Froyo Aug 23, 2019
    F_Mateo_Bratanić_aDzP , Aug 23, 2019 :
    astralbee
    Then I would say: get a LIFE and stop playing with phones!
  17. rich2e
    Froyo Aug 23, 2019
    rich2e , Aug 23, 2019 :
    9.0.5 has been much greater than Oreo and the previous pie builds. Am ready for 9.0.6, 9.0.6 WHERE YA AT?!!!
    jscOne16 likes this.
  18. Brian OBrien
    One would imagine that if your problem was caused by the update that everybody else would be affected in the same way. Clearly, they are not.
    Auristic likes this.
  19. Tanshid_45
    Eclair Aug 23, 2019
    if I restart my device hotspot would work but the thing is I have to restart everytime :/
  20. ghostofcain
    Marshmallow Aug 23, 2019
    ghostofcain , Aug 23, 2019 :
    Look at you, bug hunting!
    1. It's not present immediately after startup. Ergo it's something starting up after reboot causing the issue.
    2. Identify what apps aren't running on start up but are running when the problem manifests.
    3. Disable or uninstall programs identified in 2, re-enable one by one until culprit is identified
    4. Result
