182
OxygenOS 9.0.5 for OnePlus 3 & OnePlus 3T
  1. ghostofcain
    Marshmallow Sep 20, 2019
  2. rahulbhosle
    Donut Sep 20, 2019
    rahulbhosle , Sep 20, 2019 :
    Hi.
    I am facing this weird issue since a few days after the Android Pie update on the 3T.
    The device's screen doesn't wake up even after pressing the power button or double tapping the screen(gesture is ON). When I double tap the screen, I can feel the vibration of the device being woken up but no display. With the power button, I can hear the screen wake-up and sleep sounds but, again, no display.
    This happens only when the device is charging or hasn't been used for long(e.g. when I wake up in the morning).
    It takes a few double taps on the screen or a few double presses of the power button to actually wake up the display.
    With the double presses of the power button, first I get a quick display off thingy(like how the picture tube of the TV would do if turned off suddenly) and then it wakes up.
    I figured this behaviour might be because of the deep sleep mode so I disabled both in battery optimisation but the issue still persists.
    Even with incoming calls, the display remains off while the phone continues to ring/vibrate. I, then, have to manually wake it up by tapping the power button.
    I have run out of options here and I am not sure if Android Pie is the culprit here.
    Can anyone from OP or this forum help me figure this out please?
    UPDATE : I recently found that the screen would randomly switch off when the device is in use while charging. Only while charging.
    Please help guys.
  3. BeingIncog
    D1562555000832 likes this.
  4. Sadam_H
    Eclair Sep 20, 2019
    Sadam_H , Sep 20, 2019 :
    After 9.0.5 Update and using for a while now have noticed that Auto Brightness is not affective as available in the previous update.. this issue consuming Battery very fast..
    OnePlus, please look into this and rectify in future update.
    Thanks.
    rich2e likes this.
  5. Muneeb Suleman Sajjad
    Gingerbread Sep 20, 2019
    Muneeb Suleman Sajjad , Sep 20, 2019 :
    Have you tried wiping the cache from recovery?
    When did you update?
    Leave the device charging over night, it helps settle the OS effectively.
    Until 9.0.6 is live, about 3 weeks to go, try the aforementioned.
    _Azim_Pathaan likes this.
  6. Muneeb Suleman Sajjad
    Pie has adaptive brightness, instead of auto brightness, which will adapt overtime as per your preference. And while doing so, it'll consume a bit more than what simple auto brightness used to.
    Just hang on there a bit longer, it'll settle.
  7. Muneeb Suleman Sajjad
    BeingIncog likes this.
  8. rahulbhosle
    Donut Sep 20, 2019
    I have done a factory reset and it hasn't helped a bit.
    The display issue still persists.
    I am thinking downgrading to Oreo and see if the issue remains so that the culprit can be isolated. If the issue remains then it's a hardware issue. If not then, it's definitely Pie.
  9. Muneeb Suleman Sajjad
    Fair enough then.
    Good luck!
  10. G_pulak_padhi_YFKn
    Cupcake Sep 21, 2019
    G_pulak_padhi_YFKn , Sep 21, 2019 :
    My phone has been showing lot of problems with system lag and no caller display while getting incoming calls after the update. Any way to fix this.??
  11. ronakpujara
    ronakpujara , Sep 21, 2019 :
    exactly. M kinda facing the same things
  12. astralbee
    Ice Cream Sandwich Sep 21, 2019
    astralbee , Sep 21, 2019 :
    The new "adaptive brightness" learns from your preference. If it's not bright enough, or too bright, adjust it manually and Android will "learn" that's how you like the screen in that level of light. Next time, it will adjust automatically the way you like it.
    Auristic, KhunJ and D1562555000832 like this.
  13. astralbee
    It's definitely NOT "Pie" or everybody would have it.
    It's almost certainly something that went wrong during your upgrade. Factory reset just removes your apps and preferences, it might fix things you've screwed up with stuff you've added but it definitely doesn't fix anything that's broken with the installation.
    For the effort involved in you going back to Oreo you should at least try a full wipe and a clean install of 9.0.5. A full wipe using TWRP and then flash the official download. If you've never done anything like this before then it's time to learn. I guarantee it will be easier than the downgrade.
    Auristic and ghostofcain like this.
  14. astralbee
    Either they are jokers, or buffoons.
    Auristic and riteshetty like this.
  15. rahulbhosle
    Donut Sep 21, 2019
    rahulbhosle , Sep 21, 2019 :
    I agree that not everyone is having this issue but I'm definitely not alone. A few people replied to my thread with the same issue and I also found a few threads regarding this issue as well later.
    I'll try the twrp flash as suggested by you.
  16. KhunJ
    KhunJ , Sep 21, 2019 :
    I tried to upload TWRP. I get an error, says can't upload file.
    Any suggestions.?
  17. D1564335250345
    Donut Sep 21, 2019
  18. Prattech
    Honeycomb Sep 22, 2019
    Prattech , Sep 22, 2019 :
    Someone found solution for incoming caller ID lag issue ? Driving me crazy for months !
  19. Muneeb Suleman Sajjad
    Gingerbread Sep 22, 2019
    Muneeb Suleman Sajjad , Sep 22, 2019 :
    I wiped cache from recovery menu, worked for me.
    No lag anymore.
  20. Muneeb Suleman Sajjad
    Make sure your device doesn't go on power saving mode at 50%.
    Android 9 made power saving percentage customizable, in the battery section.
    Do cross check!
