190
OxygenOS 9.0.5 OTA for OnePlus 5 and OnePlus 5T
  1. G_Javier_Alejandro_Lopez
    Eclair May 3, 2019
    G_Javier_Alejandro_Lopez , May 3, 2019 :
    You enable a parallel WhatsApp and instead of showing you a new iteration of WhatsApp, just opens regular WhatsApp. That means I can't configure another WhatsApp account.
  2. yaswanth.p1
    Gingerbread May 3, 2019
    yaswanth.p1 , May 3, 2019 :
    I have the problem: my wifi keeps disconnecting and connecting!
    The others home devices are ok, the wifi works perfectly.
    is anyone have this issue?
  3. ErynOP
    ErynOP , May 3, 2019 :
    When I was on 9.0.5 WiFi worked fine, did you try to forget the WiFi and reconnect it ?
  4. yaswanth.p1
    i tried but not working
    and also i tried clear cache it not worked
  5. Not4Now
    Cupcake May 3, 2019
    Not4Now , May 3, 2019 :
    Try to check what app you're opening, because when you enable parallel apps, you should see a second icon of that app with a little difference of a little orange circle on top.
  6. G_Javier_Alejandro_Lopez
    Eclair May 3, 2019
  7. O1531788623010
    Cupcake May 3, 2019
  8. Luis Sismeiro
    Honeycomb May 3, 2019
    Luis Sismeiro , May 3, 2019 :
    LoL I fell you... You forgot to complain about camera quality and oil painting in photos. :)
    MPalmiro likes this.
  9. Luis Sismeiro
    Good to hear this from you. I still have to update my OnePlus 5 to Pie but seems the things are OK now.
    F_Steve_Quillen_cIJj likes this.
  10. Danial.yaqub
    Cupcake May 3, 2019
    Danial.yaqub , May 3, 2019 :
    haven't tested the new build long enough to answer this but a way I found to stop that fps drop is by turning adaptive battery off in the settings. You can try it and let me know if it works for you.
  11. X1555576956090
    Donut May 4, 2019
    X1555576956090 , May 4, 2019 :
    sometimes finger sensor does not work to unlock
    .i ll have to push unlock button then use fingerprint
    W1554647118636 likes this.
  12. W1554647118636
    Donut May 4, 2019
  13. W1554647118636
    Donut May 4, 2019
    W1554647118636 , May 4, 2019 :
    Me to.
  14. W1554647118636
    Donut May 4, 2019
  15. georgesunnyt
    Gingerbread May 4, 2019
    georgesunnyt , May 4, 2019 :
    I'm having this issue
  16. O1556942832235
    Cupcake May 4, 2019
    O1556942832235 , May 4, 2019 :
    hello 1 plus crew, can i ask why my Bluetooth is not appearing to any bluetooth device
    when i click Bluetooth on, the bluetooth symbol is not appearing on my screen, pls help me
  17. Deactivated User
    May 4, 2019
  18. J.Karthigeyan
    Cupcake May 4, 2019
  19. S1520124702248
    Froyo May 4, 2019
  20. W1554647118636
    Donut May 4, 2019
    I don,t have any lag on 5t.
    Mustasim and Paul_W_ like this.
