190
OxygenOS 9.0.5 OTA for OnePlus 5 and OnePlus 5T
  1. Mustasim
    Ice Cream Sandwich May 4, 2019
  2. morikee
    Eclair May 4, 2019
    Mustasim likes this.
  3. Mustasim
  4. morikee
    Eclair May 4, 2019
  5. Mustasim
  6. morikee
    Eclair May 4, 2019
  7. @muku_7
    Eclair May 4, 2019
    @muku_7 , May 4, 2019 :
    It is very unpleasing that after the update the phone is lagging too much. Please fix it.
    The battery performance has improved a bit.
    I hope oneplus fixes this lagging.
    Romanelo and mohammednagori like this.
  8. Zaphodrocks
    Zaphodrocks , May 4, 2019 :
    Zero lag for me. Your apps aren't optimized.
    Jontalk5 likes this.
  9. mohammednagori
    Cupcake May 4, 2019
  10. Temme_oneplus
    Cupcake May 4, 2019
    Temme_oneplus , May 4, 2019 :
    I can't use my fingerprint button since last update which I installed the 4th of may 2019. I also had to reset my whole phone because of this update it would not come out of the loading screen you get when your phone is starting up I now lost everything on my phone and also have to reinstall the whole lot of it. what do I do
  11. jumjunm
    Cupcake May 4, 2019
    jumjunm , May 4, 2019 :
    after update my one plus 5 to 9.0.5 I have problem with playing games and music keeps pausing and plays and pausing and plays again. can someone help me please with this issue thanks
  12. OnePlus OxygenOS
    Honeycomb May 4, 2019
    OnePlus OxygenOS , May 4, 2019 :
    my first charge was bad, now on the second charge & it's looking better...
  13. cubanorafter
    Froyo May 4, 2019
    cubanorafter , May 4, 2019 :
    Updated my OP5 a couple days ago, from 9.0.4, and no issues so far. Battery is fine, no lag in my apps, but never experienced that in any of the Pie updates beginning at 9.0.0. I do notice that it is not running as hot as it was on previous versions so that is good.
  14. Jontalk5
    Gingerbread May 5, 2019
    Jontalk5 , May 5, 2019 :
    I'd suggest you tap on About>build number and enable Developer Mode. Then go to Animations (all 3 of them) and change to either "0" or ".5" That way you eliminate the lag you're speaking about. I suspect you own the OP5 rather than the 5T? I have NO problems at all with the update on my 5T but the number of apps installed are minimal, NO games, utilities or others that would slow the device. It's snappy as hell, charges faster than ever and the battery life is outstanding!
    W1554647118636 likes this.
  15. W1554647118636
    Donut May 5, 2019
  16. alexisonza07
    alexisonza07 , May 5, 2019 :
    i never having lag issue.. try to clear your cache in recovery mode..
  17. W1554647118636
    Donut May 5, 2019
    W1554647118636 , May 5, 2019 :
    "always use oneplus switch to backup and restore data before update"
    Thats what they say before every update.
    Temme_oneplus likes this.
  18. Cervantes
    Moderator Moderator May 5, 2019
    Cervantes , May 5, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, read the first post
    Thread merged
  19. VidyaSagar_425
    Cupcake May 5, 2019
    VidyaSagar_425 , May 5, 2019 :
    in my phone frequent contacts are automatically cleared for every 24 hrs after this update please share any sollution
  20. StevenPicton
    Donut May 5, 2019
    StevenPicton , May 5, 2019 :
    Anyone else noticing faster battery drain after this update on OnePlus 5? Is something being automatically turned on via update which I need to turn off?
    Chirag sadani likes this.
