190
OxygenOS 9.0.5 OTA for OnePlus 5 and OnePlus 5T
  1. needa
    Honeycomb May 8, 2019
    needa , May 8, 2019 :
    A lot of that seems to be issues with Pie, and not OxygenOS. The FP sensor turns off when the phone goes into deep sleep. Nothing you can do. And there is a new algorithm for the auto brightness. Not sure if that is what is affecting you, but it takes a while for it to level out (from what peeps say on this thread).
    I don't know about night mode. Other than last night I was thinking to myself that it wasn't on. But never really gave it any thought.
  2. D1557340910109
    Cupcake May 8, 2019
    Gokulram Rajendran likes this.
  3. DanGreenstein
    Froyo May 8, 2019
    ouaille13320 likes this.
  4. G_Michał_L_VJCp
    Gingerbread May 8, 2019
    G_Michał_L_VJCp , May 8, 2019 :
    After longer time of usage I can say that this is the best Pie OTA so far. UI is smooth, fingerprint/double tap unlocking randomly stop working seems solved. Battery stats are pretty much the same which is really good. Google play auto update apps work randomly but usually doesn't auto update apps, this has been an issue since Pie release. Other than that it's perfectly good update. I'm going to send logs to OP as to auto update issue. This has to be fixed, even though it's not big deal.
    jim1024, ouaille13320 and danycmoi like this.
  5. IvanPeychev
    Cupcake May 8, 2019
    IvanPeychev , May 8, 2019 :
    very strange...everything was very smooth when i was on 9.0.4. I decided to do a hard reset, because my storage was almost full. after the hard reset i wiped the cache....and the lag appeared on 9.0.4. i updated to 9.0.5, wiped the cache...and there is lag again.
  6. Akki2894
    Cupcake May 9, 2019
    Akki2894 , May 9, 2019 :
    While using Google camera whenever I take a selfie it takes below (screenshot) mentioned pics.. Pls can anyone help me with this..
  7. fahrysholahuddin
    Cupcake May 9, 2019
  8. A1514808643305
    Cupcake May 9, 2019
    A1514808643305 , May 9, 2019 :
    thank you. no, I have not tried the beta version before... is this a beta version that is pushed through? if so, I would rather wait...
    Mustasim likes this.
  9. Mustasim
    Ice Cream Sandwich May 9, 2019
    Mustasim , May 9, 2019 :
    no dear. its the main version.
    A1514808643305 likes this.
  10. jstzzyt
    Cupcake May 9, 2019
    jstzzyt , May 9, 2019 :
    I found the perfect solution to fix the disappearing of speed dial list just now! No need to root to back up or roll back to old version. Just download the fixed version from APKMirror. Seems like this bug was found a week ago, the fixed 3.3.2 version can be installed to replace 3.4.0 version. The app in Play Store has been downgraded. The link is the search results page, and download the first version will be fine.
    https://www.apkmirror.com/?post_type=app_release&searchtype=apk&s=oneplus launcher
    Hope this helps.
  11. ouaille13320
    Eclair May 9, 2019
    ouaille13320 , May 9, 2019 :
    same observation with same update in my case.
    needa likes this.
  12. harshil970
    Cupcake May 9, 2019
  13. ichinisan
    Honeycomb May 9, 2019
    ichinisan , May 9, 2019 :
    does anyone else have Bluetooth connectivity issues after updating to 9.0.5 from 9.0.4? I'm having issues reconnecting to my Bose QC 35. Had zero issues before.. re-pairing does not fix the issue
  14. Paul_W_
    Paul_W_ , May 9, 2019 :
    That's normal behaviour if you are not rooted and have applied the fix
  15. Akki2894
    Cupcake May 9, 2019
    So is there any solution for this other than rooting?
  16. Paul_W_
    None that I'm aware of. Someone else will comment if there is
  17. C1557482331732
    Cupcake May 10, 2019
  18. JAISONGURU
    Gingerbread May 10, 2019
    JAISONGURU , May 10, 2019 :
    can I get back the old dialer
    where I could slide right from the address book to dial and see the log?
  19. jstzzyt
    jstzzyt , May 10, 2019 :
    Please check the solution on # 949 floor. I think this would help. I also want someone else to test this. Thx. [e]1f60a[/e]
  20. Nishad Ashraf
    Froyo May 10, 2019
    Nishad Ashraf , May 10, 2019 :
    latest updating heating problem normal usage and charging time auto disconnect dash charging please not this bug.. some time normal usage 5t now ironbox
