197
OxygenOS 9.0.5 OTA for OnePlus 6T
  1. J1541808863284
    Donut Nov 10, 2018
    J1541808863284 , Nov 10, 2018 :
    On behalf of actual breathing decent human beings of technology.... THANK YOU!!!! Are you perfect? No! Have you once again created something very special and unique? Yes! I have no real complaints here. I don't need or want a headphone jack and I don't use wireless charging. The speed and construction of the phone is where I needed things to be, and you deliverd. Lastly, if you don't know already, the added on screen protectors and case added to the package is a very real important touch that set you apart, so thank you.
    So on to Oxygen 9.0.5,l. It works very well. I dont see any glitches myself and think that the movement and flow is very fluid. I haven't had any crashes and or lock ups so that is very important. I also don't sense any leakage in battery performance, so I can rest a little easier with that.
    Only one piece of advice..don't ever forget your way. No matter how many times you see trolls and haters, never stop believing in your first vision and doing the things that make you different. Most of all, Never Stop listening"
    G_Nitin_Rana_sdWq likes this.
  2. KTwingstrom
    Eclair Nov 10, 2018
    KTwingstrom , Nov 10, 2018 :
    Updates after unlocking will still go through tmobile. This is due to the hardware limitation presented by the physically different radio in the tmobile variant. If you want updates faster you're gonna have to sell that tmobile variant and buy the unlocked version. That's what I'll be doing very soon.
    EngineerGunter likes this.
  3. KTwingstrom
    Eclair Nov 10, 2018
    I would work with support to get a warranty. I'm getting over 6 hours of screen time no problem. Sounds like a bad unit or serious bug. Wipe first and then try contacting support if the issue persists.
  4. Planbbobby
    Eclair Nov 10, 2018
  5. EngineerGunter
    Froyo Nov 10, 2018
    EngineerGunter , Nov 10, 2018 :
    thanks for the clarification
    At the very least, I could flash it myself at each update, but at a cost: an unlocked bootloader meaning no Android Pay, etc...
  6. KTwingstrom
    Eclair Nov 10, 2018
    Right, but you could only flash the version that was currently available for the tmobile variant. The normal rom will not work on the tmobile variant ever. ¯\_(ツ)_/¯
  7. One_Plus_Lover_Miu
    Froyo Nov 10, 2018
    One_Plus_Lover_Miu , Nov 10, 2018 :
    l am so happy to receive this lastest update after i got my 6T last night! need to test more from today! thanks guys!
  8. EngineerGunter
    Froyo Nov 10, 2018
    Well, if I'm going back to the flashing scene, I'd probably go back to CyanogenMod (now Lineage OS). Just like the good ol' bacon (OPO) days. I'm probably a little rusty... it's been years.
  9. Ultimodrew
    Honeycomb Nov 10, 2018
    Ultimodrew , Nov 10, 2018 :
    This reeks of the Samsung Galaxy Nexus that was on Verizon... Was not a true Nexus device and Sammy/Verizon sucked at updates. But I believe One plus and TM are better at it, or at least trying to.
  10. KTwingstrom
    Eclair Nov 10, 2018
    That works!
  11. KTwingstrom
    Eclair Nov 10, 2018
    Yeah I hope so. So far I'm 3 updates behind....
  12. Ultimodrew
    Well if they are pushing out this many updates, then I would assume it's in TMobiles court at this point. So hopefully released soon.
  13. agnivesh53
    Froyo Nov 10, 2018
  14. Ultimodrew
    can you expand on that? Details
  15. agnivesh53
    Froyo Nov 10, 2018
    agnivesh53 , Nov 10, 2018 :
    after this the battery is draning more am getting only 5,6 hours of use earlier I used to get 1 day
  16. Ultimodrew
    Did you notice if anything is using up more battery than it should? You might need to check to see if the update upset a rogue app.
  17. c5ingh
    Cupcake Nov 10, 2018
    c5ingh , Nov 10, 2018 :
    ***Problem****Random Vibrations (2 day old 6T))***
    Hi seems this issue has been well documented by many users on older models. So far I cannot see any resolution to this so flagging and hoping the devs look at this since it's a problem faced across many devices.
    Vibrations happen randomly whilst phone screen is on or off and screen off. It vibrates as if there is a notification however when you check the phone nothing is there.
    This issue is very annoying as well as confusing since you feel like you're missing notifications but actually not.
    I am new to OnePlus with the 6T and generally my experience has been good. However given the fact that the issue is still being experienced by users (have seen posts related to op5 upwards)...seems like this is the has been missed from fixes it is a little concerning that this won't be sorted out.
    Please can this be looked into with some haste?
    Thanks
    Ultimodrew likes this.
  18. amarisrama
  19. V1539690777519
  20. R1541820052617
    R1541820052617 , Nov 10, 2018 :
    Hello, just bought OnePlus 6T. The rear camera is good but the front is fraustrating. Am I the only one having problem with it? Do you have any suggestion to improve my camera experience to my new device?
    mohsinanadaf likes this.
