211
OxygenOS 9.0.6 for OnePlus 3 & OnePlus 3T
  1. palc
    Ice Cream Sandwich Nov 22, 2019
    Andrei R. likes this.
  2. netllocke
    netllocke , Nov 22, 2019 :
    It's called EOL shutdown ! Thanks to OnePlus
    sochaux_, rich2e and Meet@321 like this.
  3. F_Henrik_Madsen_wfQs
    Gingerbread Nov 22, 2019
    F_Henrik_Madsen_wfQs , Nov 22, 2019 :
    So is there any android 10 roms out there that works well enough to be flashed onto a phone that is the daily driver for me. ?
    If yes, what rom do you recommend.
    I have the 3
  4. mariosneo
    Cupcake Nov 22, 2019
    mariosneo , via OnePlus 3T , Nov 22, 2019 :
    Hello,
    I made the last and final update two days ago and I'm still facing cellular battery drain issues and also the system update app keeps crashing everytime I'm trying to start it.
    I yet didn't find a solution so any advice would be helpful. I already tried reset my device.
    Thank you in advance.
  5. G_Subrat_Nayak_eMEB , via OnePlus 3T , Nov 22, 2019 :
    Guys please confirm if cell standby battery drain still there
    bupapa and G_Anita_Pradhan_rEnU like this.
  6. gazz1701
    Jelly Bean Nov 22, 2019
  7. RakibulRakin
    Donut Nov 22, 2019
  8. Nemet_tt
    Eclair Nov 22, 2019
  9. Topper_Gas
    Topper_Gas , Nov 22, 2019 :
    Maybe for your phone but 9.0.6 with the latest security update is running fine on my 3.5 yr old OP3, for any outlay of just over £300 I've had fantastic support from OP during that time.
    Fábio Alves and r.hutton like this.
  10. Nemet_tt
    Eclair Nov 22, 2019
    Nemet_tt , via OnePlus 3T , Nov 22, 2019 :
    Yes, but when the battery is consuming faster, when the phone rings and you cannot answer, when it is locked, when the applications are shut down, and when you have no money for oneplus 7 pro the best solution is 5.0.8 and android 8.0.0
    capriady78 likes this.
  11. bobocu
    Donut Nov 22, 2019
    bobocu , Nov 22, 2019 :
    dear users how would you describe the experience about the new update? battery, performance?
  12. YourAvgOnePlusUser
    YourAvgOnePlusUser , via OnePlus 6 , Nov 22, 2019 :
    Never personally owned it, but I remember really wanting one. I still love this device, it's beautiful, fast, and longevity is a priority in OnePlus! I still cannot believe that a 400$ phone got that much software support. I hope that it gets even better, and my OnePlus 6 gets even more than 3 yrs. Thanks, OnePlus for making such an incredible piece of tech that lasted this long. Hopefully it will live a lot more with the use of custom ROMs!
    Never Settle.
    Kerkdriel and keithgpowell like this.
  13. PTuT
    Jelly Bean Nov 23, 2019
    PTuT , via OnePlus 3 , Nov 23, 2019 :
    Problem to install update on encrypted phone with unlocked bootloader (when you want to upgrade from 5.0.x).
  14. PTuT
  15. rich2e
    Gingerbread Nov 23, 2019
    rich2e , Nov 23, 2019 :
    I have not hard reset yet since Oreo here, same issue.
  16. rich2e
    I hope so as I've had this same issue even after send to service center for other. They should've just upgraded the camera module then.
  17. rich2e
    Seemed to start out VERY well, then issues with battery drain again, stalling/lagging before and after some black screen another user mentioned having here. At this point, as I type, it's running smooth, but with excessive battery drain; after recent full charge.
  18. rich2e
    They're the same F thing.
