225
OxygenOS 9.0.6 for OnePlus 3 & OnePlus 3T
  1. wospino
    Ice Cream Sandwich Dec 14, 2019
    wospino , via OnePlus 7 Pro , Dec 14, 2019 :
    RIP OnePlus 3/3T... no more updates will come...
  2. sunnyvarma222
    Donut Dec 15, 2019
    sunnyvarma222 , via OnePlus 3 , Dec 15, 2019 :
    +1
    keithgpowell likes this.
  3. keithgpowell
    Ice Cream Sandwich Dec 15, 2019
  4. ghostofcain
    Marshmallow Dec 15, 2019
    ghostofcain , Dec 15, 2019 :
    https://forums.oneplus.com/forums/oneplus-3-3t-3rd-party-dev/
    You're braver than me, I wouldn't update any device without access to a pc, what if it'd bricked? Obviously had you had access to a pc you'd have backed up anything important.
    Auristic likes this.
  5. Xplozv
    Cupcake Dec 15, 2019
    Xplozv , via OnePlus 3T , Dec 15, 2019 :
    Thanks for sharing this.
    although I have gone through this post before couple of times and also XDA, I'm waiting for OnePlus's own team to share some work done by developers.
    cheers!!!!
  6. niemanie
    Donut Dec 15, 2019
    niemanie , Dec 15, 2019 :
    I may have some backup because this is not my primary phone for time being. buynot of the music which is the only reason I have my phone on vacation :)
    But ever since I bought this phone, al updated went smooth. So being on vacation now I had no idea that it would went this bad.
    oneplus has of course no interest in hearing the problems. As the phone gets no support any longer. But it has been stable as rock always.
    not sure if it is hilarious that it went great for many years and the absolute last update broke the phone completely.
    I had no access to PC. I just pressed update when it mentioned it on the phone that is has been downloaded and ready to install.
    this was simple as big shame it went so bad :-(
    but it seems that not many others had the same issue. That’s what I was curious about when writing the comment :)
  7. B1523118639406
    B1523118639406 , Dec 15, 2019 :
    xiexie
  8. B1523118639406
  9. ghostofcain
    Marshmallow Dec 16, 2019
    ghostofcain , Dec 16, 2019 :
    I'm assuming that your bootloader is unlocked? If so everyone is in the same boat, as OOS pie has an issue with decryption of earlier builds, on bootloader unlocked encrypted devices.
  10. aswathknalin
    Froyo Dec 16, 2019
    aswathknalin , Dec 16, 2019 :
    i didnt upgraded my 3t till yesterday. all these years it was the stock os. bcoz of seeing many bugs in new updates. hope this is a reasonable update to do. hope everything will be fine
  11. niemanie
    Donut Dec 16, 2019
    niemanie , Dec 16, 2019 :
    I haven’t changed anything since I bought the phone. So unless one plus delivered the phone unlocked, then it else. Else it’s not unlocked :)
    that’s why I’m surprised that the latest android updates should cause this massive destruction of the phone. For me very wired. It never failed and I’m not doing any things/installing anything that could break anything. But thanks for the explanation though.
  12. aswathknalin
    Froyo Dec 17, 2019
    aswathknalin , Dec 17, 2019 :
    just updated to latest version. After this apps are not downloading from Google play store. it stucks at waiting for download. Auto Update is turned off. Download over any network is turned on. what else to look at. please help
  13. xjotjotx
    Honeycomb Dec 17, 2019
    xjotjotx , Dec 17, 2019 :
    Had you try to cancel the cache of the play store app?
    Go to the drawer, make a long tap on play store app icon and select "info" from the menu that will appear, then go to "archive space" or something like that, now you will see two button, tap on "Cancel cache".
    Another thing to do after an update is to clear the cache of all the system (you will not lose any app), to do this you need to reboot the phone in bootloader option.
    I hope this will help you,
    bye
    aswathknalin likes this.
  14. PTuT
    Jelly Bean Dec 17, 2019
    PTuT , via OnePlus 3 , Dec 17, 2019 :
    I had unlocked bootloader and encrypted phone, so to update to the latest OOS, I had to wipe the phone off. All done, restored. Happy this pain is over. System works fine without an issue just battery performance is reduced. Now, I am ready for custom ROM.
    niemanie and keithgpowell like this.
  15. C1547919677037
    Cupcake Dec 17, 2019
    C1547919677037 , via OnePlus 3T , Dec 17, 2019 :
    Porque no implementan la utilidad de que el AOD funcione aún cuando el modo de ahorro de energía este activo,sin más que decir se despide este usuario desde 🇩🇴🇩🇴R.D.🇩🇴🇩🇴
  16. Ranjit_gadde
    Froyo Dec 17, 2019
  17. Rajeesh Sasidharan
  18. PTuT
    I wiped out the phone before upgrading to the latest OOS and I do not experience problem with installing or updating apps.
  19. Gaston NP
    Lollipop Moderator Dec 18, 2019
    Gaston NP , Dec 18, 2019 :
    Please speak english for this thread.
  20. aswathknalin
    Froyo Dec 18, 2019
    aswathknalin , via OnePlus 3T , Dec 18, 2019 :
    yes. i have tried that before this post. aftee several reboots it came to normal. anyway thanks
    xjotjotx likes this.
