102
OxygenOS 9.0.6 OTA for OnePlus 5 and OnePlus 5T
  1. zerosixteen Froyo Jun 12, 2019
    zerosixteen, Jun 12, 2019 :
  2. ouyamaster Honeycomb Jun 12, 2019
    ouyamaster, Jun 12, 2019 :
    Will this update work on a rooted phone with twrp or do I need to download a twrp compatible file elsewhere?
  3. redlinecoatings Ice Cream Sandwich Jun 12, 2019
    redlinecoatings, Jun 12, 2019 :
    For the love of God DO NOT install any of those crap apps. They are full of garbage adds and the dont do a damn thing but drain your battery more. If you want to talk steps to improve battery life there's a pinned thread or you can PM me. But please do not put that garbage on your phone. Apps like that are the reason a lot of these members are having issues with updates.
    Edgar Palau, scp41, davkos and 4 others like this.
  4. needa Honeycomb Jun 12, 2019
    needa, Jun 12, 2019 :
    Anyone else notice that Google Photos magically switched to dark mode after the update? I saw that it would mimic your theme setting a few days ago, but wasn't happening for me till update.
    27 hours of uptime since update. I don't see any difference at all in how my phone performs. Still same scroll jitter. Still showing 15% and 5% battery notifs.
    edit: Other than those two things, my device is working splendidly. No complaints. Note: My dialer doesn't seem to be deleting recents.
  5. Himanshu0000608 Ice Cream Sandwich Jun 12, 2019
    Himanshu0000608, Jun 12, 2019 :
    try reset app preferences.. it will only delete apps not their data.
    do backup contacts
    or do a full wipe.. once
    I am not facing any lag. and battery without gaming is easily giving me 8hrs+ sot.
    blueskywhale likes this.
  6. spektrum2k11 Cupcake Jun 12, 2019
    spektrum2k11, Jun 12, 2019 :
    audio equalizer for Bluetooth mode?
  7. Q1545504703112 Gingerbread Jun 12, 2019
    Q1545504703112, Jun 12, 2019 :
    I've factory reset and reflashed the os but no luck, the lag is still there and it hasn't improved since pie was first introduced
    Sree321 likes this.
  8. D1512628737819 Cupcake Jun 12, 2019
    D1512628737819, Jun 12, 2019 :
    Am I the only one that got stutter/lag fixed this update? It was laggy since pie and now 9.0.6 it's finally fixed
    juanrugge, Shadink and stevenchow90 like this.
  9. Matthieu95490 Cupcake Jun 12, 2019
    Matthieu95490, Jun 12, 2019 :
    Hi
    since I had OxygenOS 9.0.6 I have problems with localisation GPS system on MAPS and WAZE.
    Can't find my position when I'm driving.
    There is no GPS signal.
    Is there any solutions for this problems?
    Thx
    Mat
  10. Martin Bonnet Gingerbread Jun 12, 2019
  11. Matthieu95490 Cupcake Jun 12, 2019
    what you mean?
  12. Martin Bonnet Gingerbread Jun 12, 2019
    Martin Bonnet, Jun 12, 2019 :
    It's pretty cool : when you turn on your OnePlus Bullet, you have like a notification and the pairing is instant ! there's also a toast notification telling you that you earphones are connected and how much battery left
  13. Himanshu0000608 Ice Cream Sandwich Jun 12, 2019
    did you wipe cache??
  14. Himanshu0000608 Ice Cream Sandwich Jun 12, 2019
    wipe cache from recovery...
    download speed cleaner.. it will clean junk
    then clear apps cache..
    may be it will solve!
  15. Matthieu95490 Cupcake Jun 12, 2019
    I tried but nothing fixed :(
  16. Shubham Gujjar Honeycomb Jun 12, 2019
  17. Himanshu0000608 Ice Cream Sandwich Jun 12, 2019
    god knows then.. for me its buttery smooth
    and battery is amazing!
    did you follow all steps that i mentioned??
  18. Matthieu95490 Cupcake Jun 12, 2019
    yeah I followed all what you said ...
    I talked with oneplus support and the only things they said to me is doing factory reset ...
  19. I1530254299940 Eclair Jun 12, 2019
    I1530254299940, Jun 12, 2019 :
    disable hardware overlay in developer setting
  20. Shadink Eclair Jun 12, 2019
    Shadink, Jun 12, 2019 :
    I agree, no lag or stuttering after the update
    juanrugge and danycmoi like this.
