103
OxygenOS 9.0.6 OTA for OnePlus 5 and OnePlus 5T
  1. G_Иван_Пейчев_ Cupcake Jun 12, 2019
    G_Иван_Пейчев_, Jun 12, 2019 :
    i just followed all the steps...and for 2 days now i havent noticed any lag...I also left the phone the whole night on the charger after doing the above steps.
  2. Q1545504703112 Gingerbread Jun 12, 2019
    Q1545504703112, Jun 12, 2019 :
    I'll try that but I can't see it working, and also what's the logic/science between leaving the phone on charge overnight because I've seen several people mention that
  3. G_Иван_Пейчев_ Cupcake Jun 12, 2019
    i've read a post before....that leaving your phone charging for the night...helps the system do some optimization....which is only possible if your phone is on charge, it has 100% battery, and is in no motion.
  4. Q1545504703112 Gingerbread Jun 12, 2019
    Ok I will give it a try, if not I think it's time to switch. That pixel 4 renders looking real good right now lol
  5. Q1545504703112 Gingerbread Jun 12, 2019
    For real though, it's been 6 months now and no one has found a fix for the lag issue. What should I do now?
    dareknowak likes this.
  6. rajat0409 Froyo Jun 12, 2019
    rajat0409, Jun 12, 2019 :
    I've been updating my phone ever since pie got released. And after every update, I've factory reset my phone via recovery (including full wipe). And I've never faced any issues till date whatsoever. No lags. No battery drain issues. Camera does decent job(not outstanding though). Everything is fine!
    jim1024 likes this.
  7. Q1545504703112 Gingerbread Jun 12, 2019
    I tried everything but no luck
  8. rajat0409 Froyo Jun 12, 2019
    Maybe hardware issue!
  9. Q1545504703112 Gingerbread Jun 12, 2019
    Rolling back to 5.1.7 fixed it and many others are also having the issue so it's not hardware based
  10. rajat0409 Froyo Jun 12, 2019
    Or, maybe I got lucky[e]1f602[/e][e]1f602[/e]
  11. X1512096539338 Cupcake Jun 12, 2019
  12. Roberta_Cisotto Cupcake Jun 12, 2019
    Roberta_Cisotto, Jun 12, 2019 :
    Now my Bluetooth doesn't work anymore. I can't pair any new devices and the Bluetooth icon won't show in the top bar. Please fix it, I've tried everything
  13. Androidb Cupcake Jun 12, 2019
    Androidb, Jun 12, 2019 :
    I feel like the earpiece volume is much better now. where there any changes made to the software for this? Before I could barely hear people on the other end with the volume all the way up. So far so good now.
    og_mick_one likes this.
  14. S1560330715520 Cupcake Jun 12, 2019
    S1560330715520, Jun 12, 2019 :
    Many missed calls if using data. If someone calls when I am in internet, using data, the phone seems to be turned off to those calling. A message about the missed call let me know...Huge problem with my Oneplus 5T , cant understand the fault..thougth with this update will get better, but not!!
  15. Carlostatic Cupcake Jun 12, 2019
    Carlostatic, Jun 12, 2019 :
    hi,
    Anyone else has lost the quick setting to get on offline mode on Spotify after updating?
    Mine has completely disappeared.
  16. Carlostatic Cupcake Jun 12, 2019
  17. N1511937203904 Eclair Jun 12, 2019
  18. salauddin@007 Eclair Jun 12, 2019
    salauddin@007, Jun 12, 2019 :
    call merging is becoming big issue. please fix it. it hangs many times while conferencing calls.
  19. hassan5482 Eclair Jun 12, 2019
  20. needa Honeycomb Jun 12, 2019
    needa, Jun 12, 2019 :
    You could have done that without the app. Guess what I have never needed to do... Delete junk from my phone.
    So it deleted 2gb. You also gave a thousand companies and several government's your data. If you are willing to make that trade... Cool. But you shouldn't be suggesting others do the same. They might not want to give full network access to a no name.company, THAT PUTS 2019 ON THEIR APP ICON! (LMAO), along with full access to your storage, and any USB storage that you may or may not connect at a later date. And your camera, your contacts, your everything.
    I'm not trying to pick on you. I am just pointing out what that app is doing.
