102
OxygenOS 9.0.6 OTA for OnePlus 5 and OnePlus 5T
  1. E1515751992883 Cupcake Jun 13, 2019
    E1515751992883, Jun 13, 2019 :
    me also but when I using recoding with I audio not coming from speakers
  2. Q1545504703112 Gingerbread Jun 13, 2019
  3. rahin456 Cupcake Jun 13, 2019
  4. stevenchow90 Gingerbread Jun 13, 2019
  5. I1516719084438 Cupcake Jun 13, 2019
    I1516719084438, Jun 13, 2019 :
    yes it is draining fast
  6. cbali Cupcake Jun 13, 2019
    cbali, Jun 13, 2019 :
    Facing issues while calling somebody as the icon on the calling page disappear. Attached snapshot will make it more meaningful . Kindly look into this and fix asap
  7. I1516719084438 Cupcake Jun 13, 2019
    better don't download. so many issues are there. battery draining fast, speed dial is not working
    rahin456 likes this.
  8. Kamal Hans Ice Cream Sandwich Jun 13, 2019
  9. rahin456 Cupcake Jun 13, 2019
    rahin456, Jun 13, 2019 :
    Thanka
  10. J1560439591385 Cupcake Jun 13, 2019
    J1560439591385, Jun 13, 2019 :
    hi,
    My microphone isn't working when I have connected my earphones. I have tried different earphones it's not working. I'm not sure it's with this app or not. could you please help me to resolve this issue ASAP.
  11. angelshl96 Cupcake Jun 13, 2019
    angelshl96, Jun 13, 2019 :
    My cameras aren't working after installing the update. No matter if it's through the Camera app or doing a video call using some other app, such as Skype for example.
    piotrox likes this.
  12. Yagu1206 Cupcake Jun 13, 2019
  13. aftabali297 Eclair Jun 13, 2019
    aftabali297, Jun 13, 2019 :
    did you sideload the oreo rom via pie recovery?
  14. dareknowak Froyo Jun 13, 2019
  15. Q1545504703112 Gingerbread Jun 13, 2019
    Q1545504703112, Jun 13, 2019 :
    I just flashed it via local upgrade. Are you rooted?
  16. aftabali297 Eclair Jun 13, 2019
  17. dareknowak Froyo Jun 13, 2019
  18. Q1545504703112 Gingerbread Jun 13, 2019
    In that case you should probably use lineage os, a stable pie experience without bugs. Pixel experience is pretty good too.
  19. juanrugge Eclair Jun 13, 2019
    juanrugge, Jun 13, 2019 :
    quick update. im on 9.0.6 for 4 days now, and the lag problems are much better (present in my 5t since Pie), yet not at the level of smoothness that i have on last Oreo. in the other hand, im not really sure, but seems battery consumption is a bit higher..
    i have experience the problems of deleted contacts on phone app, only while i was on 9.0.5, but this stop after a couple of days, while on 9.0.5.
    power/unlock button problem, where sometimes you have to press twice to activate the screen (manly after a long time without using it), its still present.
    my update path was: last oreo to 9.0.3, factory reset, erase everything, and start from zero, and from there, i kept updating has updates came on, always erasing cache afterwards.
    P1560712816485 likes this.
  20. F_Sneha_Poddar_MEyF Cupcake Jun 14, 2019
