243
OxygenOS 9.0.6 OTA for the OnePlus 6T
  1. AFRIDI.S.PATHAN
    Donut Nov 22, 2018
  2. Daniel_125
    Eclair Nov 22, 2018
    techysandy likes this.
  3. NaveenRajJackob
    Donut Nov 22, 2018
    NaveenRajJackob , Nov 22, 2018 :
    i am not get the update..what's the problem?
  4. Daniel_125
    Eclair Nov 22, 2018
    Daniel_125 , Nov 22, 2018 :
    Wait man. They can't push the update to all users at the same time. I am waiting too
    NaveenRajJackob likes this.
  5. NaveenRajJackob
    Donut Nov 22, 2018
    ok ..i am waiting
  6. Ni7547
    Froyo Nov 22, 2018
    Ni7547 , Nov 22, 2018 :
    is there any heating issue?
  7. Daniel_125
    Eclair Nov 22, 2018
  8. K1541939756962
    Eclair Nov 22, 2018
  9. Saif_Ghole
    Froyo Nov 22, 2018
    Saif_Ghole , Nov 22, 2018 :
    Hi All,
    OnePlus 6T is a very good device in terms of hardware, but when it comes to software OnePlus has released a half baked software or untested software over the time being.
    In my opinion its one of the First device to come with so many bugs after launch which are not yet fixed.
    There are many bugs till now which are unnoticed.
    1- Random vibration: Phone vibrates randomly as if you have received any notification, but there's no notification.
    2- Even after updating to 9.0.6 the notification for many apps are not coming up.
    3- Battery optimization is worst, Apps like Whatsapp, Snapchat, instagram, OnePlus Launcher, PlayServiices , etc consumes the maximum of charge with minimal usage.
    for example, 19min of Snapchat consumes 8-12% of charge,
    10 min of Instagram consume 6-7% of charge.
    PS: I know the power consumption depends on the usage, but I feel the power management is a bit buggy with the software released.
    4- Many UI falws: In the latest release 9.0.6 the back button disappears when you are on home screen. Is this a UI change?
    5- Even when you are using a dark theme the Navigation bar turns out to be white for manu application which uses dark themes
    6- Adaptive brightness issues, Most of the time it doesn't work. I have to adjust the brightness manually
    7- Whatsapp, Snapchat ,etc notification doesn't comes until you open the App. This happen even when you have selected Don't Optimize in battery saving & Adaptive battery is turned off.
    8- Widgets in Shelfs consumes too much of spaced, i.e. you get the widget Header twice in shelf. 1 is with the Widget and other with the Card Header.
    9- Stories gets cropped in WhatsApps Instagram etc,
    10- YouTube videos don't utilize the complete space. It might be that the Video uploader need to make some changes but can't comment
    11- KeyBoard doesn't work..need to restart the device. If we try to force close Gborad app, the phones hangs up and then need a Soft reset to work
    PS:
    These might be app specific issues which need to be fixed by the Developer of Whatsapp or Instagram or Snapchat but don't have any confirmation on them.
    NOW comes the biggest Issue i.e. the Fingerprint sensor.
    When you are using split screen you can't use the Sensor nor you are allowed to type in the password as the keyboard wont pop up.
    Also while using banking apps like Kotak, for making some transaction you need input the PIN, you can't make transaction with just using the Fingerprint. In such cases the Fingerprint overlap with the 8 digit which makes it very difficult to enter the PIN.
    @Jeff H. It would be great if you look at current issues. :)
  10. Swapnil Roy
    Cupcake Nov 22, 2018
  11. Ajay K S
    Eclair Nov 22, 2018
  12. B_Wrath
    Nougat Nov 22, 2018
    B_Wrath , Nov 22, 2018 :
    Turn off advanced battery optimization.
    Both are poorly optimized apps. They are a known source of battery drain.
  13. varunrsh
    varunrsh , Nov 22, 2018 :
    guys, can anyone point me to the instructions for updating via downloaded file ?
  14. Sayantan1
    Donut Nov 22, 2018
    Sayantan1 , Nov 22, 2018 :
    I hope it will improve daylight images and also focusing issue and white balance issue in night camera
  15. margusmaki
    Froyo Nov 22, 2018
    margusmaki , Nov 22, 2018 :
    system > system update > gear icon > local upgrade
  16. varunrsh
    Thank you, but it says i have to move the downloaded file to the root folder... cannot see the root folder from File Manager
  17. camohan
    Moderator Moderator Nov 22, 2018
    camohan , Nov 22, 2018 :
    Thread merged. It is important that right information is provided to right audience in a right way.
  18. Pinttas
    Honeycomb Nov 22, 2018
    Pinttas , Nov 22, 2018 :
    A few pages before ... and guess what?
    the same questions that have been answered many times in this topic.
  19. DANish1214
    Gingerbread Nov 22, 2018
  20. DANish1214
    DANish1214 , Nov 22, 2018 :
    download vpn app n change your region to Canada n u will get update
