243
OxygenOS 9.0.6 OTA for the OnePlus 6T
  1. SidMAX86
    Honeycomb Nov 24, 2018
    SidMAX86 , Nov 24, 2018 :
    Can someone confirm this behavior????
    Open any app that uses system share menu (e.g. Chrome), Three dots share to bring up share menu...lock the device using power button.....wake up screen using power button....
    Now the lockscreen is supposed to appear (if you are not using faceunlock)....however I am getting a transparent lockscreen where I can see the app in the background...
    Starcommander likes this.
  2. pias36
    Cupcake Nov 24, 2018
    pias36 , Nov 24, 2018 :
    You didn't fix the basic BUGS!
    1. Phone doesn't vibrate on vibration mode. It remains silent. In Ring Mode, the phone doesn't vibrate even though call vibration is turned on!
    2. FB Messenger sound doesn't stop even though sound is OFF on messenger app.
  3. Praveen@0201
  4. pias36
    I used VPN and chose Canada as my location and got the update. It didn't work on my default location (USA).
    DrPraveen_Upadhyay likes this.
  5. SidMAX86
    My two cents...Have you made sure vibration is not turned off in accessibility....Settings/Accessibility/Vibration/Ring&Notification vibration...
  6. Praveen@0201
    Praveen@0201 , Nov 24, 2018 :
    but why should I change vpn when in India people also get update
  7. ChandraShekar143
    Donut Nov 24, 2018
    ChandraShekar143 , Nov 24, 2018 :
    my Oneplus 6t device didn't get any updates ,why oneplus 6t update 9.0.6 limited devices ,when will get this update ??
    shantanunaresh likes this.
  8. SidMAX86
    As stated by OP:
    "This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs. Using VPN to download this build might not work as the rollout is not based on regions and is randomly pushed out to a limited number of devices."
    I don't know the exact method they use to decide who gets the update but ppl have been saying that Using VPN seems to be working in getting the update early ( Region Canada)
    Shekar444 and pias36 like this.
  9. samprocat
    samprocat , Nov 24, 2018 :
    yes you will when they roll out in stages
  10. pias36
    You'll get it. It just take time sometimes. Not everybody get the update at the same time.
    Luq01 likes this.
  11. samprocat
    Not much have been improved under the hood at least for problems I'm getting
    9.0.6
    JelleZon likes this.
  12. RoshanChhetri
  13. JelleZon
    OnePlus Accessory Tester Nov 24, 2018
  14. aj.au
    Eclair Nov 24, 2018
    aj.au , Nov 24, 2018 :
    used VPN and picked Germany , fingerprint has definitely improved in unlocking phone quicker . great job guys
  15. ChandraShekar143
    Donut Nov 24, 2018
    Thanks for explaination
    SidMAX86 likes this.
  16. RoshanChhetri
  17. X1527229544395
    Froyo Nov 24, 2018
  18. K1541939756962
    Eclair Nov 24, 2018
    K1541939756962 , Nov 24, 2018 :
    these gestures are a bit slow, hope they have fixed that problem.
  19. Starcommander
    Starcommander , Nov 24, 2018 :
    Nope working fine. Lockscreen appears
  20. Chris1205
    Donut Nov 24, 2018
    Chris1205 , Nov 24, 2018 :
    I noticed my 6t's fingerprint sensor to work a lot faster than before. Thank you One plus
