243
OxygenOS 9.0.6 OTA for the OnePlus 6T
  1. smartass08
    Donut Nov 28, 2018
  2. rudrex
    Donut Nov 28, 2018
    rudrex , Nov 28, 2018 :
    thanks
  3. Smokey409
    Eclair Nov 28, 2018
    Smokey409 , Nov 28, 2018 :
    holy cow I just re-registered my finger and it's sooooooo much faster crazy how the update has improved it.
  4. I1541417770798
    Eclair Nov 28, 2018
    I1541417770798 , Nov 28, 2018 :
    problem may. arise - It's better to avoid -
    if you like troubleshooting you can go ahead with the Install
  5. vahidhm
    Donut Nov 28, 2018
    vahidhm , Nov 28, 2018 :
    I have serious battery drain after this update. can I roll back? what's the suggestion?
    urielejh likes this.
  6. rohan.pipalwa
    Donut Nov 28, 2018
  7. urielejh
    Cupcake Nov 28, 2018
  8. Abhishek Raj_2109
    Froyo Nov 28, 2018
  9. M1543036167442
    M1543036167442 , Nov 28, 2018 :
    in also having the same issue. it's super annoying.
  10. vahidhm
    Donut Nov 28, 2018
    same for me, just tested it...
  11. Deactivated User
    Nov 28, 2018
    U1543369369968 likes this.
  12. aakashmaji16
    Gingerbread Nov 28, 2018
    aakashmaji16 , Nov 28, 2018 :
    there are some unnecessary vibration after this update. no notification arrive but still there is vibration!
    Tiger53 and U1543369369968 like this.
  13. Ultimodrew
    Honeycomb Nov 28, 2018
    Ultimodrew , Nov 28, 2018 :
    No issues with it that I can see.
  14. S1541970247621
  15. ALXTRR
    Donut Nov 28, 2018
    ALXTRR , Nov 28, 2018 :
    I was having the same issue, could contacted support and instead of fixing the problem they made do a factory reset. once I did the phone work for a good 5 minutes and after that went back to same issue third party apps not working. contacted support again for nothing cause they couldn't figure out what the problem. despite the fact that I did the new update which would fix these problems. I got tired of it and just decided to return the phone. I really like the phone but the software needs lots of work still.
    V3X11 likes this.
  16. Danmccabe
    Froyo Nov 28, 2018
    Danmccabe , Nov 28, 2018 :
    Such a great update by the team. my fingerprint scanner is so much faster and battery life is very well optimised.
  17. I1543133959973
    Donut Nov 28, 2018
  18. SidMAX86
    SidMAX86 , Nov 28, 2018 :
    This is for registering for the Closed Beta Group ...Correct??? On a Computer, login to OnePlus Community, Click your profile picture (or hover over it and click Profile)...the url on your browser would be your Profile URL..
  19. I1543133959973
    Donut Nov 28, 2018
  20. Saenz4931
    Saenz4931 , Nov 28, 2018 :
    have you tried to reboot in to recovery and delete cache, or just wiping Google assistant cache, and data, reboot your phone and set it again?
