244
OxygenOS 9.0.6 OTA for the OnePlus 6T
  1. TheAyushJain
    Honeycomb Nov 21, 2018
    TheAyushJain , Nov 21, 2018 :
    F_Jeet_Shah_GKFH
    make sure it isn't running on the background when u try clearing it from the status bar , should solve your problem​
    Maybe this sounds weird , I didn't had this kind of problem on my OP5.
    When I started using OP6T I got this issue
  2. P1541125383858
    Donut Nov 21, 2018
    P1541125383858 , Nov 21, 2018 :
    Not yet at least. Last update took 2 weeks for the T-Mobile varients to receive it.
    m1ster0wl likes this.
  3. F_Jeet_Shah_GKFH
    Donut Nov 21, 2018
    F_Jeet_Shah_GKFH , Nov 21, 2018 :
    it's not a bug , if a application is running in the background you cannot terminate it without shutting it down , so you need to make sure that it isn't in the background before u clear it from the status bar
  4. TheAyushJain
    F_Jeet_Shah_GKFH
    it's not a bug , if a application is running in the background you cannot terminate it without shutting it down , so you need to make sure that it isn't in the background before u clear it from the status bar​
    Okay. I get it. But it is still not convenient
    But Google Play music supports swipe to remove on the first pause
    Maybe it is an issue on the app developer's side
  5. sepa_2000
    Cupcake Nov 21, 2018
    sepa_2000 , Nov 21, 2018 :
    ravikiranpv
    Can you guys fix the issue with Instagram stories being cropped/clipped?​
    That's a problem with instagram itself. Every phone with other than 16:9 aspect ratio, exept iPhones I think
  6. F_Jeet_Shah_GKFH
    Donut Nov 21, 2018
    needs to be done from Instagram , can't be helped from op
  7. Saenz4931
  8. Josiah1231
    Gingerbread Nov 21, 2018
    Josiah1231 , Nov 21, 2018 :
    anyone know how you can flash the global OOS to get these updates on a t mobile device?
  9. geoff5093
    Eclair Nov 21, 2018
    geoff5093 , Nov 21, 2018 :
    I know it's a long shot, but anyone on 9.0.6 found that it works with Verizon without having to call them to add CDMA_Less?
  10. Pratik78
    Froyo Nov 21, 2018
  11. Android450
    Marshmallow Nov 21, 2018
  12. Pratik78
    Froyo Nov 21, 2018
    Pratik78 , Nov 21, 2018 :
    Sorry but it has also got bugs!!
  13. Android450
    Android450 , Nov 21, 2018 :
    And I'm sure people will somehow find bugs on this one. You'll just have to wait it out or search the forums for a solution
  14. Pratik78
    Froyo Nov 21, 2018
    Yeahhh
  15. Mirko96
    Donut Nov 21, 2018
    Mirko96 , Nov 21, 2018 :
    it seems that the screen unlock speed has improved even more after the update but unfortunately when you unlock it on ambient mode it still increases the brightness of the whole screen, and not just the sensor's area like it correctly does in the lockscreen. It can be very annoying at night. Please fix it!
  16. rs1
    rs1 , Nov 21, 2018 :
    Just came here for the comments... and they did not disappoint, lol.
    Carry on.
    Pinttas, Android450 and Diego2214 like this.
  17. Idalbertopm22
  18. V3X11
    Froyo Nov 21, 2018
    V3X11 , Nov 21, 2018 :
    Wtf is with third party app notifications?!! I'm not getting them at all. I read about battery optimization and sleeping apps but it's not working for me...coming from Samsung Galaxy S8 + this is unacceptable...besides that big problem for me the phone is gorgeous and blazing fast... OnePlus fix this ASAP! Thanks
    PS I'm on 9.0.6 and the same problem...
    android.racer likes this.
  19. margusmaki
    Froyo Nov 21, 2018
    margusmaki , Nov 21, 2018 :
    Same, tried usa, germany etc but only canada worked!
  20. M1542416409960
    Froyo Nov 21, 2018
    M1542416409960 , Nov 21, 2018 :
    amazing OnePlus I've got the 6T and I'll trade this one as soon as OnePlus 7T releases.[e]1f60d[/e][e]2764[/e]️
