243
OxygenOS 9.0.6 OTA for the OnePlus 6T
  1. Starcommander
    OnePlus Accessory Tester Dec 2, 2018
    Starcommander , Dec 2, 2018 :
    Bro disable smart lock entirely. Switch off location. Probably smart lock is made to keep your phone unlocked at your home
    anasac90 and Pinttas like this.
  2. Saenz4931
    Honeycomb Dec 2, 2018
  3. goadamn
    Eclair Dec 2, 2018
    goadamn , Dec 2, 2018 :
    woah, the transparent fingerprint reader is choice!
    would love for that to be an option without rooting. I'm sure some people will complain because they'll get errors when not placing their finger in the correct spot, but for those of us who have a general understanding of how fingerprint scanning works, this would be lovely.
    Seagal_aikikai likes this.
  4. Deactivated User
    Dec 2, 2018
    Starcommander likes this.
  5. Starcommander
  6. F_Wassim_Al_ihal
    Gingerbread Dec 2, 2018
    F_Wassim_Al_ihal , Dec 2, 2018 :
    maybe OnePlus can fix the volume issue. it feels like you keep increasing the volume from zero to 60% and the volume increases just a little bit. this issue I guess was in OnePlus 5/5t in the early updates.
  7. S1543782960381
    Cupcake Dec 2, 2018
  8. Saenz4931
    Saenz4931 , Dec 2, 2018 :
    delete your Playstore cache, data, and uninstall any Google playstore update.
    S1543782960381 likes this.
  9. Orsonlebon
    Eclair Dec 3, 2018
    Orsonlebon , Dec 3, 2018 :
    nope obviously u don't know how that works
  10. U1541388896274
    Cupcake Dec 3, 2018
  11. mituldebnath
    Cupcake Dec 3, 2018
  12. robbieast
    Cupcake Dec 3, 2018
    robbieast , Dec 3, 2018 :
    ugh battery went from 9-10hrs of sot to 6-7hrs since the update?
    I thought this update was suppose to better the battery :(
  13. weakenfalls
    Eclair Dec 3, 2018
    weakenfalls , Dec 3, 2018 :
    show us how you use the phone cause it's almost impossible to get 9-10 sot....6-7 that's what I got in heavy usages. honestly I don't see why people complaining bout battery if you're getting 6-7 sot, most flagship phones out there average bout 4+ and 5 max if even that.
    kgiorgionek and Pinttas like this.
  14. reylimo
    Gingerbread Dec 3, 2018
    reylimo , Dec 3, 2018 :
    Auto dim is very low always. At very low light purple colors makes ghosting.
    Please improve auto dim. Also I don't see the magnifying lens when pushing screen for selecting a text. It appears on pixel 3 and it's very useful
  15. Abhishek Raj_2109
    Froyo Dec 3, 2018
  16. f00tbaLL
    f00tbaLL , Dec 3, 2018 :
    Wireless charging? You have a plug in the wall which the USB cable comes out of and connects to a wireless charging point/pad and then you put your phone on it which charges slowly and can get knocked off accidentally or alternatively you ever plug in the wall which the USB cable comes from and plug it directly into your phone and it charges at least twice as quick so which one is better? When you go away or out and about you only have to carry a USB cable and not also the wireless charging pad.
    Do understand how it works and was a fan of it with the old Samsung S6 but soon realised it was an hindrance rather than plus.
  17. Kumar_oneplus 6T
    Cupcake Dec 4, 2018
  18. JMulder99
    Cupcake Dec 4, 2018
    JMulder99 , Dec 4, 2018 :
    my battery is now draining faster. Don't get me wrong, my OP6T lasted 2 days before the update. Now, it is more like 1,3 days
    adi1001 and Desejmon like this.
  19. 3FFA
    Eclair Dec 4, 2018
    3FFA , Dec 4, 2018 :
    might be something you changed, an app you added or a different way you tried using the device
  20. deepu1488
    Cupcake Dec 5, 2018
    deepu1488 , Dec 5, 2018 :
    yes same mine too.
