243
OxygenOS 9.0.6 OTA for the OnePlus 6T
  1. JMulder99
    Cupcake Dec 5, 2018
    JMulder99 , Dec 5, 2018 :
    me too. hopefully.it will be better with the next update
  2. Orsonlebon
    Eclair Dec 5, 2018
    Orsonlebon , Dec 5, 2018 :
    àgain obviously you don't go out much there's plenty of places where you càn do that .... charge your phone wireless like Starbucks, airport ànd restaurants.
    just saying
  3. G_Mr_Gworld_EvSX
    Cupcake Dec 5, 2018
    N1543267098402 likes this.
  4. SAMI ALAM KHAN
    Donut Dec 7, 2018
  5. incbxsx
    Cupcake Dec 8, 2018
  6. Siddhant2902
    Froyo Dec 12, 2018
    Siddhant2902 , Dec 12, 2018 :
    there is a bug and the bug is when you Open WhatsApp in 6T and in status(story) zone when you zoom your camera to 8x OnePlus Hangs I also attached a Screenshot ... Please try this I am not kidding ..
    JMulder99 likes this.
  7. Debasis_M
    Cupcake Dec 17, 2018
    Debasis_M , Dec 17, 2018 :
    thank you.. resolved..
  8. Debasis_M
    Hi team,
    while chatting in fb messenger most of the time it get hanged. frequently I am facing this issue..can anybody facing the same issue..
  9. skgcruzr
    Froyo Dec 17, 2018
  10. JMulder99
    JMulder99 , Dec 17, 2018 :
    can't. but what you can do is resetting your phone and not updating it.
  11. skgcruzr
    Froyo Dec 17, 2018
    skgcruzr , Dec 17, 2018 :
    if i reset will it go to 9.0.5 or 9.0.6?
  12. JMulder99
    I think 9.0.5. but I am not 100% sure if it will downgrade
  13. skgcruzr
    Froyo Dec 17, 2018
    wat happened to OP5 type of flashing OS in 6t from internal storage method to downgrade or upgrade? did they remove it?
  14. skgcruzr
    Froyo Dec 17, 2018
    i thot i cud simply download and install from internal storage and downgrade easily...(
  15. xkiddoh
    Honeycomb Dec 18, 2018
    xkiddoh , Dec 18, 2018 :
    Prasun_Saha_6T
    I found this on another thread..
    Hello,
    I am able to download apps from google play but problem is it doesn't show any progress of download on the notification panel. Previously on 9.0.4. It only showed a notification after the download was completed but while downloading nothing but after 9.0.5 it is not even showing that also.
    NOTE: It's now fixed for me
    I've found a workaround, check if this works or not.
    Here solution for this weird bug
    1. Go to Settings, Apps & notifications, see all apps, touch 3 dot, Show System, find Android Setup(i had 2 android setup one can't be cleared and the other can be cleared) go to Storage and clear storage.
    2. Back to Settings again, search Download Manager, open Notification, click on in progress and done, set them both to "Show silently".(but i have set all 3 of them In progress, Done & Queued to 'Show silently')
    3. Reboot
    Credits: Sandy_b94​
    It is not a bug it seems. Its part of android Pie and was preset this way.. But i did what you said and now its perfect. Thanks!
  16. adi1001
    Honeycomb Dec 19, 2018
    adi1001 , Dec 19, 2018 :
    yes it is happening since updated to 9.0.7 but they said tht they improved battery in changelog of 9.0.7.
  17. adi1001
    yes happening with me also.....lot of battery drain while it is in idle
  18. Utkarsh_Gupta_0506
    Froyo Dec 20, 2018
    Utkarsh_Gupta_0506 , Dec 20, 2018 :
    waiting for 9.0.8 to come out..
    as per discussion with software engineer, i got to know the problem is with modem settings..
    soon it should be fixed..
    adi1001 likes this.
  19. adi1001
    Honeycomb Dec 20, 2018
    adi1001 , Dec 20, 2018 :
    ohh thank u for update........hope so they will realese it as early as possible...
  20. Utkarsh_Gupta_0506
    Froyo Dec 20, 2018
    6-7 sot is not bad.. when we we all saw 8-9 sot nobody wants the reduced feature..
    bugs would be rectified.. but it would be great to rollback to previous working software version.. i hope this feature could be provided by OnePlus team
