171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. JamesBoulder
    Gingerbread Jul 24, 2019
    JamesBoulder , Jul 24, 2019 :
    You can sideload Zen mode, it works like charm.
  2. Khems91
    Khems91 , Jul 24, 2019 :
    Screen recorder is useless unless it records internal audio to stereo channel.
    but not, it's recoding audio to mono channel.
  3. wrldtvlr
    wrldtvlr , Jul 24, 2019 :
    So far, so good. Don't want to jinx things, but I'm not seeing the constant loss of wifi data connection I had been seeing.
  4. Sid_Ck
    Ice Cream Sandwich Jul 24, 2019
    Sid_Ck , Jul 24, 2019 :
    I'm guessing it's some port issue... or some software issue... check with your nearest service centre
  5. volverOP5T
    Honeycomb Jul 24, 2019
  6. volverOP5T
    volverOP5T , Jul 24, 2019 :
    only gingerbread and above are getting the updates. Your profile is still cupcake. Cupcakes will get it last.
    danishdaycare and yash_bohra123 like this.
  7. ChiranthAtharvaa
  8. ChiranthAtharvaa
  9. mynameisg
    Cupcake Jul 24, 2019
  10. FenilKhatiwala
    Froyo Jul 24, 2019
    FenilKhatiwala , Jul 24, 2019 :
    Oneplus should work on improving camera quality. No camera improvments since last so many updates.
    rajeev5252 and Jeshuu like this.
  11. Jeshuu
  12. musadsaiyed
    Froyo Jul 24, 2019
    musadsaiyed , Jul 24, 2019 :
    volverOP5T
    only gingerbread and above are getting the updates. Your profile is still cupcake. Cupcakes will get it last.​
    maybe its random
  13. HaroldNL
    Froyo Jul 24, 2019
    HaroldNL , Jul 24, 2019 :
    I was on beta, so I downloaded the then available firmware on the computer.
    I locked bootloader, went to recovery and sideloaded the firmware, startup the phone, reinstall all the apps and did the update via the updater.
    so here I am on the latest firmware [e]1f60a[/e][e]1f44d[/e]
  14. U1511495604731
    Eclair Jul 24, 2019
    U1511495604731 , Jul 24, 2019 :
    Guys which way should I update to new version full update or incremental update through oxygen updater ??
    currently on 9.0.6
  15. 09479888823
  16. devanshsadhotra
    devanshsadhotra , Jul 24, 2019 :
    i came from beta to stable today ! how long will it take to recieve? or updates are just random?
  17. rockinsnake
    Froyo Jul 24, 2019
    M1542334491701 likes this.
  18. devanshsadhotra
    i have used these two in BETA, nothing special actually! it just tells u the app usage time and all. you took never settle too seriously
  19. JamesBoulder
    Random but you will receive it within a week, I guess.
    devanshsadhotra likes this.
  20. reojo
    Froyo Jul 24, 2019
