171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. Ced357
    Eclair Jul 25, 2019
    Ced357 , Jul 25, 2019 :
    same for me
  2. A1513676329230
    Donut Jul 25, 2019
    A1513676329230 , Jul 25, 2019 :
    I am from India... My one plus 5t has not received this update till now... Not even VPN is helping.. Does anyone from India have received it.?
  3. Paul_W_
    Honeycomb Jul 25, 2019
    Paul_W_ , Jul 25, 2019 :
    So you've received it then?
  4. A1513676329230
    Donut Jul 25, 2019
  5. Paul_W_
    Try oxygen updater app to get it now or just wait for it to arrive OTA in a few days
  6. inshubhandari
    Gingerbread Jul 25, 2019
  7. S1520124702248
    Froyo Jul 25, 2019
    S1520124702248 , Jul 25, 2019 :
    I have set my notification in the Gaming mode as text only, but when I am not playing any game it comes as a text only instead of heads-up. Unable to find the option to change the notification display for normal screen.
    Rakshit_Patil likes this.
  8. saiSumanth1+
    saiSumanth1+ , Jul 25, 2019 :
    no I won't received it ,,stil VPN is no use
  9. X1519563315070
    Cupcake Jul 25, 2019
    X1519563315070 , Jul 25, 2019 :
    Install latest version of recorder 2.2.0
  10. shahbaj alam
    shahbaj alam , Jul 25, 2019 :
    not again my bro....
    I'd done the same, screen recorder did not work....
    had to do factory reset....
  11. X1519563315070
  12. Paulomsc
    Eclair Jul 25, 2019
    Paulomsc , Jul 25, 2019 :
    Uau equipe OP, que top, vocês realmente se preocupam com seus clientes e nós ficamos muitos satisfeitos pelas atualizações mesmo com dois anos do aparelho, muito obrigado por ser a empresa que nos adoramos. E queremos mais novidades hehe
    Luis Sismeiro likes this.
  13. aurobinda143
  14. antonio ray
    antonio ray , Jul 25, 2019 :
    Salve .... io ho avuto problemi fin dai primi aggiornamenti ad Android pie .... il telefono rallenta vistosamente quando scorro il menù ....questi bug sono presenti anche nella versione 9.0.7?
  15. Deactivated User
    Jul 25, 2019
  16. antonio ray
    ho provato fare proprio il ripristino ai dati di fabbrica ma dopo un po i rallentamenti si ripresentano....alla fine sono tornato ad Oreo 5.1.7 con cui non ho problemi
  17. antonio ray
    Tra gli altri bug che avevo con Android pie c'era anche l'icona del Bluetooth che non compariva nella barra di stato quando veniva attivata
  18. antonio ray
    Deactivated User likes this.
  19. antonio ray
  20. antonio ray
    Purtroppo contattando il centro assistenza di oneplus Italia non hanno saputo darmi una soluzione per risolvere questi problemi...
