171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. Prashant kumar sangwan
    Gingerbread Jul 29, 2019
    Prashant kumar sangwan , Jul 29, 2019 :
    bro look once iphone and then tell me how much they provide latest os even .ore than 2 yr old device gettig latest os versions and hv lesser bug than andriod .
    yah op is far better then others in os related in andriod.
  2. iamitrajguru
    Donut Jul 29, 2019
  3. sufiyan.
    sufiyan. , Jul 29, 2019 :
    so you got update via oxygen updater ?
  4. iamitrajguru
    Donut Jul 29, 2019
  5. Maurizio_it_TR
    Froyo Jul 29, 2019
    Maurizio_it_TR , Jul 29, 2019 :
    I don't think he has these problems, since you almost only have them, you make a hard reset from recovery (save your data first) maybe do it in the evening, as soon as you've done, leave it in charge all night
  6. sufiyan.
    not at all bro. it's just safe when the update comes officially on your mobile. try not using other methods to get updates , you may face Lot's of bugs.
  7. iamitrajguru
    Donut Jul 29, 2019
    iamitrajguru , Jul 29, 2019 :
    so is it possible to resolve this or not? and if yes then how?
  8. Kaustub_deshpande
    Cupcake Jul 29, 2019
    Kaustub_deshpande , Jul 29, 2019 :
    after update digital seconds on watch are not running continuously, also speaker id in earphone mode is not working
  9. V1543812894693
  10. Rotten Egg
    Honeycomb Jul 29, 2019
    Rotten Egg , Jul 29, 2019 :
    Use Oxygen Updater App....I think it will be useful .
  11. sufiyan.
    open the shutter matlab uppr se kholte na notification panel where u find wifi mobile data Bluetooth waha pe slide left krna u can find more options ryt waha pr edit option hoga then u can find recorded there itself.
  12. iamitrajguru
    Donut Jul 29, 2019
    bro pls check screenshot.. It is not showing any sliding option.
    pls suggest resolution
  13. G_yan_silvantono_vABE
  14. sufiyan.
    can you see the pencil mark at down between setting icon and profile icon, touch that then you'll be able to see recording option.
    iamitrajguru likes this.
  15. iamitrajguru
    Donut Jul 29, 2019
    Thank you Bro [e]1f603[/e][e]270c[/e]️[e]1f44d[/e] It's done now.
    sufiyan. likes this.
  16. satyajeets03
    Eclair Jul 29, 2019
  17. R1514308250987
    Aswin_V likes this.
  18. kleberfo
    Donut Jul 29, 2019
    kleberfo , Jul 29, 2019 :
    Going back to Oreo will be very sad.
    I have never had problems with Pie updates, but this last update had a lot of problems or my phone started to indicate its end of life.
  19. kleberfo
    Donut Jul 29, 2019
    I'll try hard reset as a last alternative.
    But I think that out of all the problems that this latest update brought, my fingerprint stopped working due to hardware and not software failure, but it coincided.
  20. ahmed.tanveer90
    Eclair Jul 29, 2019
