171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. jmarie310
    Cupcake Jul 29, 2019
  2. DogeAlpha
    Honeycomb Jul 29, 2019
    DogeAlpha , Jul 29, 2019 :
    Myself, I'm mostly happy
    I still face occasional stutters when scrolling (quite annoying, goes away by itself in a few minutes / after a reboot)
    Getting quite a decent battery life even though my battery is like 15 months old
    I really have such high hopes for pie
  3. cubanorafter
    Froyo Jul 29, 2019
    cubanorafter , Jul 29, 2019 :
    Like many others now, I just got the OTA update for my OP5 here in the US. (I have no screenshots to prove it, sorry)
    But seriously, updated and running fine. Haven't had any issues in the past, so not expecting any lag or battery problems, but will update if things go south...
  4. X1550189810540
    Cupcake Jul 30, 2019
    X1550189810540 , Jul 30, 2019 :
    Is there anyway to change back to the way the icons were in the older version? I just upgraded to 9.0.7 and the icon blocks I think are taller, so everything is slightly more spread out. I'd like to revert that if at all possible. thanks!
    Paschfire likes this.
  5. T1533998691666
    Froyo Jul 30, 2019
    T1533998691666 , Jul 30, 2019 :
    But the Pie updates that they released has made our phones really slow and buggy compared to Oreo. Are you OK with the developer team doing this?
  6. I1516719084438
  7. S1546501068875
  8. S1546501068875
  9. Stephen sandeep
    Donut Jul 30, 2019
  10. W1554572307354
  11. G_Suresh_Loghu_fNaV
  12. G_Suresh_Loghu_fNaV
  13. ninja123456
    Ice Cream Sandwich Jul 30, 2019
    ninja123456 , Jul 30, 2019 :
    add a game/app to the gaming mode list. when the app runs you will get a notification which cannot be dismissed in efficient there will be an option to switch to fnatic mode. once you switch to fnatic mode you can access the settings from the notification itself. hope this helps.
  14. Savan_Chavda
    Eclair Jul 30, 2019
    Savan_Chavda , Jul 30, 2019 :
    Thank you OnePlus for Update [e]1f618[/e][e]1f618[/e][e]1f618[/e][e]1f618[/e][e]1f618[/e][e]1f618[/e]
  15. FauzanRajan
    Donut Jul 30, 2019
  16. Anand PM
    Honeycomb Jul 30, 2019
    Anand PM , Jul 30, 2019 :
    This is the page that was not showing before. And the issue was that i had installed the Game Space App by Oneplus which prevents this Settings from Opening. Uninstalling that app fixed it. I thought it was a bug.
  17. G_Saurabh_Bhardwaj_Jggw
    Donut Jul 30, 2019
  18. karthik2207
    Donut Jul 30, 2019
    karthik2207 , Jul 30, 2019 :
    got the update today and no issues so far.
    just to be on the safe side I immediately wiped the cache after upgrade.
  19. karthik yadawad
    Gingerbread Jul 30, 2019
  20. Maurizio_it_TR
    Froyo Jul 30, 2019
    Maurizio_it_TR , Jul 30, 2019 :
    Probably the only solution is to open it and check the connector, the update cannot cause this problem.
    However, I suggest you make an installation from scratch, clean cache and data (save your data first) and install 9.0.7 everything from recovery.
    I have done so and I have no particular problems, only the fingerprint occasionally fails to recognize the imprint.
