171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. Edgar Palau
    Gingerbread Jul 31, 2019
    Edgar Palau , Jul 31, 2019 :
    That's true. Call it "Quick settings" could be confusing, someone could think that it's in"Settings".
    Maybe it should be renamed to "Quick settings pane" or similar in future communications??
  2. Martin35
    Cupcake Jul 31, 2019
    Martin35 , Jul 31, 2019 :
    i did this update and now my device is bricked :S... laptop shows qualcomm hs-usb diagnostics 900e
    anyone have an idea to solve this?
  3. Martin35
  4. Kbzaloka
    Froyo Jul 31, 2019
    Kbzaloka , Jul 31, 2019 :
    Hi, I want to report that I still have the lag problems in the system.
    I hope you can solve. Thanks
    Y1515664120581 and anmolgoel12 like this.
  5. CarlosRod35
    Eclair Jul 31, 2019
    Y1515664120581 likes this.
  6. Teekar.2023
    Gingerbread Aug 1, 2019
    Teekar.2023 , Aug 1, 2019 :
    Just download oxygen updater from the Google play store and you'll get updates faster.
  7. Z1528162410560
    Cupcake Aug 1, 2019
  8. Teekar.2023
    download the full update package for 9.0.6 and then move it to the root directory of the phone using a computer and then boot into recovery mode and install the update package from there.
  9. B1547694081952
    Cupcake Aug 1, 2019
    B1547694081952 , Aug 1, 2019 :
    yes having same problem
  10. E1564636219936
    Cupcake Aug 1, 2019
    G1564677654854 likes this.
  11. E1564636219936
    Cupcake Aug 1, 2019
    E1564636219936 , Aug 1, 2019 :
    go to edit option and check it u'll get it
  12. M_Durga_Vara_Prasad
    Cupcake Aug 1, 2019
  13. Ravi BINAVAT
    Ice Cream Sandwich Aug 1, 2019
  14. L1564642617599
    Cupcake Aug 1, 2019
  15. anmolgoel12
    Cupcake Aug 1, 2019
    anmolgoel12 , Aug 1, 2019 :
    After this update I am experiencing issues of lagging though I am using 8GB Ram model.
    Once calling history also got disappeared.
    issues using data swtitching btw wifi and cellur.. sensing message from WhatsApp is also lagging.
    don't know only I am facing this problem or it's a general issue after this update.
  16. Martin35
    Cupcake Aug 1, 2019
    Martin35 , Aug 1, 2019 :
    i just had a talk with customer support and they say don't download this update!!
  17. V1509393844749
    Cupcake Aug 1, 2019
    V1509393844749 , Aug 1, 2019 :
    after updating 9.0.7, having problem in fast charging .having same charger before and after updating .
    what is it .
    how to delete new version .
    old is better I think .
  18. Ologu Alexandru Mihai
    Ologu Alexandru Mihai , Aug 1, 2019 :
    V1509393844749
    what is it .
    old is better I think .​
    Clean your charging port gently and look for rust on the connectors, do a restart.
    If you can borrow the OnePlus charger from a friend if he has one, and always use the red OnePlus USB withe OnePlus charger otherwise you won't get fast charging.
  19. A Walker
    Cupcake Aug 1, 2019
  20. Pratikozarker
    Donut Aug 1, 2019
    M_Durga_Vara_Prasad likes this.
