171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. Mustasim
    Ice Cream Sandwich Aug 3, 2019
    Mustasim , Aug 3, 2019 :
    definitely this will be done. : )
    N1520867783629 likes this.
  2. Suraj gurav 007
  3. N1520867783629
    Donut Aug 3, 2019
    N1520867783629 , Aug 3, 2019 :
    Suraj gurav 007
    gaming mode is not blocking any notification
    it get on screen while playing games​
    did u change ur settings to completely block the content in gaming mode ?
  4. Suraj gurav 007
    Suraj gurav 007 , Aug 3, 2019 :
    yess i have done that..but not happning a
  5. N1520867783629
    Donut Aug 3, 2019
    yeah then most probably bcoz gaming mode gets disabled after sometime which looks like an issue I reported above
  6. S1520124702248
    Froyo Aug 3, 2019
    S1520124702248 , Aug 3, 2019 :
    Having no problem after this update, as someone mentioned to clear the cache before and after the update. It makes my phone smoother, for now no complains.
    og_mick_one likes this.
  7. murat ulusakarya
    Cupcake Aug 3, 2019
  8. Zippy7
    Honeycomb Aug 3, 2019
    Zippy7 , Aug 3, 2019 :
    it's great to see updates still happening 2 years post purchase of my op5.
    I've had Android phones from other makers that never had any updates.
    mind you, I still have catssss
  9. stansuys
    Gingerbread Aug 3, 2019
  10. W1554647118636
    Donut Aug 4, 2019
    W1554647118636 , Aug 4, 2019 :
    This is not a stable update. Bugs bugs bugs.
    Still hangs on connecting a midi keyboard.
    Rendom restarts on usb tethering connection.
    Some notifications stucks in panel.
    Auto rightness not working properly.
    Thumbs down oneplus,s software team.
  11. W1554647118636
    Donut Aug 4, 2019
    Having same issue. Restart your phone and check.
    After some tries it worked for me.
    And don't forget to thumbs down to oneplus,s software team.
  12. Gopi Kiccha
    Gingerbread Aug 4, 2019
    Gopi Kiccha , Aug 4, 2019 :
    I am facing this issue...
  13. ninja123456
    Ice Cream Sandwich Aug 4, 2019
    ninja123456 , Aug 4, 2019 :
    when they have finished fixing all the bugs that were reported in beta
  14. sharafkp
    Cupcake Aug 4, 2019
    sharafkp , Aug 4, 2019 :
    after this update my display not working properly... somebody help.. or tell how to downgrade software! plzzzzzz
  15. sharafkp
    Cupcake Aug 4, 2019
    i also having the same issue... it automatically turnoff the screen.... somebody help.... !!
  16. vivekdpj
    Cupcake Aug 4, 2019
    vivekdpj , Aug 4, 2019 :
    has any one facing battery drain after this update? 5%drained with in 30 mins after reboot.
    X1548201504617 likes this.
  17. SwissQ
    Cupcake Aug 4, 2019
  18. VangelisKps
    Froyo Aug 4, 2019
    VangelisKps , Aug 4, 2019 :
    Excellent battery life, 48 hours after full charge dropped to 10%, 5 hours screen usage, wifi and Bluetooth always on cause Wear OS. No lags, no bugs, all works perfectly and smooth, upgraded my 5T last Monday
    U1564949097838 likes this.
  19. nkarast
    Cupcake Aug 4, 2019
    nkarast , Aug 4, 2019 :
    Significant drop in battery life and overall increase in temperature after this upgrade.
    I hope it's fixed soon, it's an UX killer.
  20. G_Amit_Dhangare_NTGr
    Cupcake Aug 4, 2019
    G_Amit_Dhangare_NTGr , Aug 4, 2019 :
    My battery life has been significantly reduced after the update OxygenOS 9.0.7 . It barely gives be 5 hrs SOT, whereas it used to give aroune 7 hrs SOT before the update.
    vivekdpj and U1564949097838 like this.
