171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. T1562506386460
    Cupcake Aug 5, 2019
  2. delucaserick
    Gingerbread Aug 5, 2019
    delucaserick , Aug 5, 2019 :
    Then you´re ok. Dont Worry and jus keep it on 9.0.6
  3. Inked73
    Cupcake Aug 5, 2019
    Inked73 , Aug 5, 2019 :
    Hi i'm fro madagascar,i saw the diifference in gaming mode!!it doesn't drain battery such as before!!
  4. X1548201504617
    Cupcake Aug 5, 2019
  5. Niti_yadav
    Cupcake Aug 6, 2019
    Niti_yadav , Aug 6, 2019 :
    somehow I had to reset my phone
    I lost all my data but I also got the basic version of software how should I upgrade it to the latest version in 5t
  6. vivekdpj
    Cupcake Aug 6, 2019
    vivekdpj , Aug 6, 2019 :
    what setting have you made to get this high battery life? please share your success
  7. ChiranthAtharvaa
    Gingerbread Aug 6, 2019
    ChiranthAtharvaa , Aug 6, 2019 :
    my op5 getting 5.5 hrs of sot with data & Bluetooth on
    vivekdpj likes this.
  8. vivekdpj
    Cupcake Aug 6, 2019
    congrats
    ChiranthAtharvaa likes this.
  9. gkselaknc
    Cupcake Aug 6, 2019
    gkselaknc , Aug 6, 2019 :
    Have trouble in the landscape mode.
    I am using SwiftKey keyboard.
    Check compatibility.
  10. swornakar
    Eclair Aug 6, 2019
    swornakar , Aug 6, 2019 :
    After this update the sounds leaks from speaker even when the earphone is connected. Is someone else also having this issue, or it's only me?
  11. Kum1r
    Froyo Aug 6, 2019
  12. VangelisKps
    Froyo Aug 6, 2019
    VangelisKps , Aug 6, 2019 :
    Nothing special except that the "Adaptive battery" setting is active and I have three applications, which use a lot of battery, as "restricted"
  13. T1533998691666
    T1533998691666 , Aug 6, 2019 :
    How is the K20? My experience with xiaomi has been bad so far.. They stopped providing updates to the phone after 1 year. No secrutiy updates or anything. Hardware is ok though
  14. F_Hamd_Mubarak_Zeqk
    Cupcake Aug 6, 2019
  15. ninja123456
    Ice Cream Sandwich Aug 6, 2019
    ninja123456 , Aug 6, 2019 :
    it's suggesting you to go to recovery and install your rom from there. it also means that you need to wipe data and cache since you are going back to previous version.
  16. C1540035888873
    Cupcake Aug 6, 2019
    C1540035888873 , Aug 6, 2019 :
    so with last update there is bug, while watching online video, the phone goes in sleep mode, i will later check on other players
  17. jimmyjim11
    Eclair Aug 6, 2019
    jimmyjim11 , Aug 6, 2019 :
    I get a soft reboot then I am tethering my phone to computer ☹️
    I have to enter pin number and switch back on tether the phone doesn't actually reboot just goes back to enter pin number stage ???
  18. G1514217730308
    Cupcake Aug 6, 2019
    G1514217730308 , Aug 6, 2019 :
    phone is charging slow after few days of update.
    is der any critical bug.?
    can some1 help me out here.?
  19. Mustasim
    Mustasim , Aug 6, 2019 :
    what is soft reboot?
  20. jimmyjim11
    Eclair Aug 6, 2019
    it's like the phone restarted I have to put in pin number and wait for home screen to refresh and switch back on tether
