171
OxygenOS 9.0.7 OTA for OnePlus 5 and OnePlus 5T
  1. G_Ranadheer_Vakkalagadda
    Cupcake Aug 6, 2019
    G_Ranadheer_Vakkalagadda , Aug 6, 2019 :
    I have done my oneplus5 oxygen OS 9.0.7 update recently. After doing update, my oneplus wireless bullets are not working properly. I am able to connect and listen music but the problem is when I do magnetic lock, the music is not pausing. Is there anyone facing the same issue? When Oneplus will fix this issue.?
  2. Funk Wizard
    Lollipop Moderator Aug 6, 2019
    Funk Wizard , Aug 6, 2019 :
    Thread merged with official thread, please continue to discuss your issue here for proper feedback and support
  3. G_Daniele_Spidalieri_Xgt
    Cupcake Aug 6, 2019
    G_Daniele_Spidalieri_Xgt , Aug 6, 2019 :
    after the update I noticed that silent notification option for a specific app is missing. is there a workaround for get back this function?
    thx
  4. Chand6391
    Gingerbread Aug 7, 2019
    Chand6391 , Aug 7, 2019 :
    widgets are not loading properly. lack in speed. somtimes phone getting stuck
  5. G_Abinash_Sundaram_Przz
    Cupcake Aug 7, 2019
  6. G_Abinash_Sundaram_Przz
    Cupcake Aug 7, 2019
  7. rsharma3512
    Froyo Aug 7, 2019
    rsharma3512 , Aug 7, 2019 :
    but I'm not finding any screen recorder in quick setting... can someone please guide?
  8. maortrol
    Honeycomb Aug 7, 2019
    maortrol , Aug 7, 2019 :
    You need to install the Screen Recorder apk first.
  9. maortrol
    Try to install the Screen Recorder apk first.
  10. rsharma3512
    Froyo Aug 7, 2019
  11. Edgar Palau
    Edgar Palau , Aug 7, 2019 :
    There is no need to install any apk. Please do not confuse the users with wrong information.
    In 9.0.7 update the Screen recorder function comes with it.
    To enable it just go to Quick Settings pane, then EDIT the quick settings and it will appear in the list quick settings available. Just move it to the first quick settings and that's all.
    It has been explained many times in this threat..
  12. ninja123456
    Ice Cream Sandwich Aug 7, 2019
    ninja123456 , Aug 7, 2019 :
    rsharma3512
    but I'm not finding any screen recorder in quick setting... can someone please guide?​
    please open this thread from website. In my signature there's a link to my channel. the latest video shows 2 ways to get screen recorder. hope this helps
  13. rsharma3512
    Froyo Aug 7, 2019
    thanks dear... got it...
  14. ninja123456
    don't install any APK from any source other than Play Store and don't install any rom other than ota or the stock ROM from OnePlus website itself
    Edgar Palau likes this.
  15. rsharma3512
    Froyo Aug 7, 2019
    did the same... nd got it in quick setting... thanks again
  16. dban_
    Cupcake Aug 7, 2019
    dban_ , Aug 7, 2019 :
    Same thing also for me. I've done multiple wipe cache... But nothing changes. Did you solve it?
  17. G_Amit_Dhangare_NTGr
    Cupcake Aug 7, 2019
    G_Amit_Dhangare_NTGr , Aug 7, 2019 :
    I have downgrade my device to 5.0.6, I would suggest you to do the same if security does not matters you,
  18. dban_
    Cupcake Aug 7, 2019
    Ok thanks. But i prefer to stay with the last version.
    So anybody in the community have the same issue?
  19. MihirKudale
    Froyo Aug 7, 2019
    jferraz likes this.
  20. needa
    needa , Aug 7, 2019 :
    CAREFULLY pick the lint out of your charger and charging port.
