327
OxygenOS 9.0.7 OTA for the OnePlus 6T
  1. ronnyhawks
    Ice Cream Sandwich Dec 12, 2018
    ronnyhawks , Dec 12, 2018 :
    change VPN to Germany and check for update [e]1f44d[/e]
  2. ronnyhawks
    as soon as you follow my instructions in my previous post [e]1f44d[/e]
  3. Nithin Thimaiah
    Eclair Dec 12, 2018
  4. Sandesh Ratnakar Shet
    Cupcake Dec 12, 2018
    Sandesh Ratnakar Shet , Dec 12, 2018 :
    i need more stabilization on camera. Because after snapping all pics get little shrink and blurry. So I need an update on this feature. Hope you will do it. I raised complaints on this issue through emails. But reply is like reboot. It didn't gone well.
  5. ironass
    Lollipop Dec 13, 2018
    ironass , Dec 13, 2018 :
    Storage Manager does what it says in its description... that you can free up space on your device, if need be, by removing backed up photos and videos from your phone that are older than 90 days. See screenshot, below.
    Personally, with 256GB of storage, I do not need to use it but I wish I had had it on the OnePlus 3, 64GB.
    Nithin Thimaiah likes this.
  6. G12c4
    Donut Dec 13, 2018
    G12c4 , Dec 13, 2018 :
    Battery life on 9.0.6 was perfect, I had almost 10 hours SOT and with the new 9.0.7 update I get barely 4 hours SOT, horrible
  7. Veluindia
    Cupcake Dec 13, 2018
    Veluindia , Dec 13, 2018 :
    after update calls are not clear. while speaking I'm getting echo sound. Please fix this issue as soon as possible.
  8. Veluindia
    I'm also facing this issue
  9. Nithin Thimaiah
    Eclair Dec 13, 2018
    Nithin Thimaiah , Dec 13, 2018 :
    Thanks Mate.
    Good Day (y)
  10. adi1001
    Honeycomb Dec 13, 2018
    adi1001 , Dec 13, 2018 :
    yeah they should give update for battery
  11. pspnewcomer
    Eclair Dec 13, 2018
  12. fidus62
    Jelly Bean Dec 13, 2018
    fidus62 , Dec 13, 2018 :
    Why??? The battery life is excellent!!!!
  13. adi1001
    in my case battery is not up to mark since i updated to 9.0.7 for idle drain and somehow little for screen on time .
    it was better in 9.0.6 .
  14. Abhishek_Jadhav
    Abhishek_Jadhav , Dec 13, 2018 :
    Guys there is serious ram management issues on the 6t with 8gb ram model every app which is running in background reloads the contents when I try to re-open it.
  15. adi1001
    i was facing this issue sometimes in 9.0.5 but after 9.0.6 that never happened to me.
    now i m not facing that issue.
    try wipe cache from recovery
  16. Ketanatwork
    Donut Dec 13, 2018
    Ketanatwork , Dec 13, 2018 :
    can you add a small on screen feature to display and blink as led on screen...since OnePlus 6t lacks led notification light...but led display can turn on a particular part of display by blinking when notification arrives... similar to app on Google play store as "NoLED"...but it will b great if u integrate it in lock screen feature
    HenrikOnePlus and adi1001 like this.
  17. Abhishek_Jadhav
    Is it safe ? Also will it affect the internal storage data?
    And what's the procedure to it?
    Sorry for too many questions but I'm new to the OnePlus community so it's better to ask the experts.
  18. adi1001
    yeah it is safe, in fact, thus method is suggested by oneplus team.
    it won't affect ur data , it will just clr junk files which making conflict to system .
    1. power off device
    2.press volume down and power button simultaneously untill device go into recovery mode
    3.then enter ur pin if u has to unlock ur phone .
    4.then select language
    5.wipe cache and data > wipe chache > yes> reboot
    u r done
    hope this will help u
    and its ok to ask questions, thus thread for us only to solve each other's problem and feel free to ask anything in future .....
    good day sir
    Abhishek_Jadhav likes this.
  19. binu678
    Froyo Dec 13, 2018
    binu678 , Dec 13, 2018 :
    hi,
    Recent updated 9.0.7 having more bugs and some apps having hanging problem.
    pls rectify in new updates.
    adi1001 likes this.
  20. adi1001
    yes since i updated to 9.0.7 my 2 of games crashed while playing which is asphalt 8 and asphalt 9 , but it happend with me only once per game which is mentioned
    f00tbaLL likes this.
