327
OxygenOS 9.0.7 OTA for the OnePlus 6T
  1. adi1001
    Gingerbread Dec 13, 2018
    adi1001 , Dec 13, 2018 :
    clean the display and re-register it.......it happens bcoz of moisture which is little amount on ur finger bcoz of winter season thts why it is taking tym
    u clean ur finger and display before using it and it will work as expected....thus was happening with me also then i tried this and it is working superb....
    hope so this will help u
    good day
  2. adi1001
    no ,u have dash charger, warp charger is for macleran addition which is already running on oxygen os 9.0.9.
  3. mibrs
    Donut Dec 13, 2018
    mibrs , Dec 13, 2018 :
    Before the update the battery was amazing !! 7-8 hours SOC, if gaming its around 5 h SOC .
    AFTER the update, Normal usage i get 4-5 hours SOC, if gaming its 3-4 hours.
    Any idea what to do ? Can I downgrade to the previous update ?
    It certainly pefromed better before the update.
    kyoo, B1542292200219 and adi1001 like this.
  4. adi1001
    this is also happening with us brother.........
    we can jst hope tht they will fix it next update bcoz oneplus team is very fast like their device for updates and fixing the issues of users.
    i don't know exactly that if can go to previous version or not but if this is possible then will definitely go to 9.0.6 for that i can sacrifice audio tunner for Bluetooth headset.....
  5. B1542292200219
    Donut Dec 13, 2018
    B1542292200219 , Dec 13, 2018 :
    can anyone help me with this?
  6. @anil@
    Donut Dec 13, 2018
    @anil@ , Dec 13, 2018 :
    talk to one plus customer care about downcreate .they will help you
  7. Desejmon
    Ice Cream Sandwich Dec 13, 2018
  8. kyoo
    kyoo , Dec 13, 2018 :
    holding out for better battery life in the next update here also
    B1542292200219 likes this.
  9. adi1001
  10. Desejmon
    Desejmon , Dec 13, 2018 :
    I just did clean flash 9.0.7
  11. adi1001
    see the prediction of system ....it is showing that "should last until about 10 Am ".....i mean seriously?....one charge and jst 10 hrs of standby ?this is not good
    B1542292200219 and Desejmon like this.
  12. Desejmon
    Still waiting for os 9.0.9
    D1542836311701 and adi1001 like this.
  13. adi1001
    i also did factory reset to see if there is a problem or not in the os but issue is still there
  14. adi1001
    yeah but they should improve standby battery life and screen usage optimisation in that update
    Desejmon likes this.
  15. aakashmaji16
  16. Karthi210993
    Cupcake Dec 13, 2018
    Karthi210993 , Dec 13, 2018 :
    hi jeff
    I'm experiencing a long rectangle grey strip appearing between enter pin and number pad...
    it's coming from this update 9.0.7
    gallery, WhatsApp are experiencing this kind of strip.. fix this bug ASAP ...
    thank you jeff
    waiting for your valuable reply!!!
  17. adi1001
  18. Penedene
  19. M1542507407936
    M1542507407936 , Dec 13, 2018 :
    is it the carrier that rolls out updates cause TMobile won't release updates to my wife and I phones. we both have 6t.
  20. Echovelox
    Eclair Dec 13, 2018
    Echovelox , Dec 13, 2018 :
    As with my previous Oneplus 6, my OP 6T still rings sometimes while on vibrate or silent mode (using button switch and verified in my sound settings).
    Could Oneplus fix this issue ?
    It's a real problem at work...
