327
OxygenOS 9.0.7 OTA for the OnePlus 6T
  1. G_pranav_Sard_Bspf
    Eclair Dec 3, 2018
  2. Preditor 2028
    Eclair Dec 3, 2018
    Preditor 2028 , Dec 3, 2018 :
    update is going on thx
  3. V1543849193408
    Cupcake Dec 3, 2018
    V1543849193408 , Dec 3, 2018 :
    Please Help! I logged in only to say the GPS IS SHOWING THE OPPOSITE DIRECTION HERE IN City : Far Rockaway 11691 NYC On The T-Mobile One Plus 6T and there is no fix
  4. damolitoy
    Gingerbread Dec 3, 2018
  5. V1543849193408
    Cupcake Dec 3, 2018
    V1543849193408
    Please Help! I logged in only to say the GPS IS SHOWING THE OPPOSITE DIRECTION HERE IN City : Far Rockaway 11691 NYC On The T-Mobile One Plus 6T and there is no fix​
    On Oxygen Os 9 GPS is Showing opposite direction on the US models
  6. Franck Gut.
    Froyo Dec 3, 2018
    aditya.jpeg , Dec 3, 2018 :
    use psiphon pro and change the location to Canada a
  8. Shield10
    Honeycomb Dec 3, 2018
    Shield10 , Dec 3, 2018 :
    Updates are to fix the bug.
    Oneplus 6 has less bug than 6T.
    Quantity of update is Not important But Quality is.
  9. alan mosses
    alan mosses , Dec 3, 2018 :
    For gaming section provide a screen recorder that can record game audio... [e]1f62d[/e]I'm tired of asking this over and over for the past 3months.[e]1f613[/e]
    Preditor 2028 likes this.
  10. Auristic
    Lollipop Dec 3, 2018
  11. Auristic
    Auristic , Dec 3, 2018 :
    Next time please refrain from posting useless screenshots!
  12. I1539982403974
    Eclair Dec 3, 2018
    I1539982403974 , Dec 3, 2018 :
    OnePlus can do 2 Betas for two different devices but they can't do it for the 5t. Fu*k you OnePlus
    G_Abhishek_Samuel likes this.
  13. FearMyFart
    Cupcake Dec 3, 2018
  14. I1541486871560
    Cupcake Dec 3, 2018
  15. edy90s
    edy90s , Dec 3, 2018 :
    yes, sorry it won't happen again I just was a little bit angry :-s
    Auristic likes this.
  16. G_pranav_Sard_Bspf
    Eclair Dec 3, 2018
    G_pranav_Sard_Bspf , Dec 3, 2018 :
    Dear connect phone to wifi then activate VPN then download update same u need to install
  17. I1541486871560
    Cupcake Dec 3, 2018
    I1541486871560 , Dec 3, 2018 :
    sir I doesn't have WiFi I am using only phone network so is it possible to connect in VPN sir
  18. KTwingstrom
    Eclair Dec 3, 2018
    ironass likes this.
  19. G_pranav_Sard_Bspf
    Eclair Dec 3, 2018
    Yes go to turbo vpn app right side u will see globe click on it, after that select right side option free then select country Canada that it after that u will see running bunny then it will show connected... After that. Go to seeing system then system updates then download it and install the same
    I1541486871560 likes this.
  20. Androidexpert35
    Eclair Dec 3, 2018
    Androidexpert35 , Dec 3, 2018 :
    Shishir_
    I didn't get it yet.
    Used VPN Germany, Netherlands, UK, USA. nothing seems to work...​
    just got it in Italy and updated. Everything good so far. Going to gym right now I'll test standby power consumption, let's see if it gets improved over 9.0.6 [e]1f60c[/e]
