327
OxygenOS 9.0.7 OTA for the OnePlus 6T
  1. I1542031284370 Cupcake Dec 6, 2018
    E1542967779613 likes this.
  2. Perissatto Cupcake Dec 6, 2018
  3. Praveen_Chauhan Donut Dec 6, 2018
    binu678 likes this.
  4. Arko Mustafi Eclair Dec 6, 2018
    Arko Mustafi, Dec 6, 2018 :
    Hi All,
    I'm still facing battery drain issues after the update.
    Also, the speaker volume has surprisingly gone down a lot, it's not as loud as it was before.
    Kindly help.
  5. binu678 Froyo Dec 6, 2018
  6. Satveera1 Cupcake Dec 6, 2018
    Satveera1, Dec 6, 2018 :
    bug on data not working on dual sim or second sim slot..:(
    As we all know one plus 6t is a dual sim phone. unfortunately I had set up my second sim slot as a data sim and primary slot for voice and texts. when I try to download from the Google Play Store any app it does not go well. rest all works I mean browser video calls etc works well but not play store for updating apps.
    I had to swap my sim card to primary slot or sim 1 slot to see or use the data which is more annoying. why would we have dual sim slot then?.
    also if I need to have this worked or operated I need to go for a restart of my device to have it worked. this is another issue.
    Is any one else facing the same problem. please advise.
    Also note I had to perform multiple times factory reset first it was my face unlock did not work then this data issue. grrrr pissed off for sure.
    Thanks!
  7. narceoneplus2 Honeycomb Dec 6, 2018
  8. M1544110597450 Cupcake Dec 6, 2018
  9. F_Vijay_Sharma_ZXRL Cupcake Dec 6, 2018
    F_Vijay_Sharma_ZXRL, Dec 6, 2018 :
    lock screen wallpaper looks dull and discolored after the recent update please test the update and release even the camera quality has gone poor battery performance is degrading night scape mode is not any different from regular camera pictures in night.. also check if night scape mode could be made available for selfies..
    Arko Mustafi likes this.
  10. Arko Mustafi Eclair Dec 6, 2018
    9.0.5 had the best battery life.
    camera quality is degrading and the display and speakers have lost the original quality.
    Nithin Thimaiah likes this.
  11. St_Jacob Froyo Dec 6, 2018
    St_Jacob, Dec 6, 2018 :
    Working perfect here. Bad luck dude.
  12. Emines007 Ice Cream Sandwich Dec 6, 2018
  13. Syamlal Krishnan Donut Dec 6, 2018
  14. Emines007 Ice Cream Sandwich Dec 6, 2018
  15. Hiten.Shah Froyo Dec 6, 2018
    Hiten.Shah, Dec 6, 2018 :
    same here. I am also facing both issues.
  16. vikrantsawant Cupcake Dec 6, 2018
    Vamsi Saladi likes this.
  17. v0 HaVoK 0v Ice Cream Sandwich Dec 6, 2018
    v0 HaVoK 0v, Dec 6, 2018 :
    Does anyone know if the slow motion performance improvement is a fix for the frame skipping and will it come to the 6
  18. FedericoZanellaZanette Cupcake Dec 6, 2018
  19. Vamsi Saladi Gingerbread Dec 6, 2018
    JayasundarRB likes this.
  20. Surya_Man_Dangol Donut Dec 6, 2018
    Emil Huth likes this.
