327
OxygenOS 9.0.7 OTA for the OnePlus 6T
  1. Rahul oP6T
    Donut Dec 9, 2018
    Rahul oP6T , Dec 9, 2018 :
    Actually 'slow motion' videos were way better before this update. Now it sucks.
    Update should always improve the quality but the results are opposite.
  2. chopra2392
    Cupcake Dec 9, 2018
    chopra2392 , Dec 9, 2018 :
    these are the things they need to improve at any cost
    D1544073973229 likes this.
  3. Kaustubh1992
    Cupcake Dec 9, 2018
    Kaustubh1992 , Dec 9, 2018 :
    Since 9.0.6 OTA update, my phone has stopped vibrating for incoming calls. It vibrates during start up and alarms but not during incoming calls. Please help!
  4. AshuEltero
    Froyo Dec 9, 2018
    AshuEltero , Dec 9, 2018 :
    Standby battery drainage increased after new update. Please help to solve the issue.
  5. Saish_B
    Donut Dec 9, 2018
    Saish_B , Dec 9, 2018 :
    After the new update.....
    1- Internet speed got reduced somehow . (check speed on other device and it was higher than on this one).
    2-Play store download getting stuck after 100+MB.
    3-Only kind of improvement I noticed is idle battery consumption reduced by certain amount.
    They said it's fast
    they said it's speed
    so far all I got to see is nothing
  6. E1541609041040
    Cupcake Dec 9, 2018
    E1541609041040 , Dec 9, 2018 :
    It's great and working fine.
    please solve my problem.
    Video Casting problem for Amazon Prime Videos, Jeo Cinema, Jeo Tv shows etc.
    with my Oneplus 6T mobile, while casting Amazon prime videos, video signal is not getting cast on my Vu TV , where as audio is ok. I am not facing any problem with my other Samsung galaxy,-7 and other make mobiles.
    Please suggest any solution.
    with thanks & regards,
    K. Satyanarayna.
  7. Srikanth_mudavath
    Eclair Dec 9, 2018
    Srikanth_mudavath , Dec 9, 2018 :
    8+ hours off SOT is achievable with 9.0.7 here is the proof
  8. JayasundarRB
    Ice Cream Sandwich Dec 9, 2018
    JayasundarRB , Dec 9, 2018 :
    where have you cleared the cache?
  9. JayasundarRB
  10. Srikanth_mudavath
    Eclair Dec 9, 2018
    JayasundarRB
    how have you achieved this ?​
    yes see post #1668 I have shared screen shots as well.
    1. remove adaptive screen
    2. clear cache of Google Play services.
    3. and optimise all the apps .
  11. G_Danny_Honey_DehR
    Cupcake Dec 9, 2018
  12. SpHenk
    Cupcake Dec 9, 2018
    SpHenk , Dec 9, 2018 :
    I just bought a 6t and I got the 9.0.7 almost right away. I'm experiencing a lot of random reboots. At least a couple of times a day. I have wiped the cache and also did a factory reset of the phone. The phone freeze and then restarts... I have googled my *** of but haven't found anything. Has someone seen this issue or recognize it at all or am I the only one?
    Thanks for your help
  13. Srikanth_mudavath
    Eclair Dec 9, 2018
    SpHenk
    Thanks for your help​
    u better get your phone replaced , that's a hardware issue .
    SpHenk likes this.
  14. Saish_B
    Donut Dec 9, 2018
    Sometimes my phone freezes too and they said it's a big and wait for new updates but still get freezes like every 4-5 days after restart. Never got forced restarted though .
    Jannick_Joosten and SpHenk like this.
  15. ashvin9
    Donut Dec 9, 2018
  16. Eric Cancel
    Cupcake Dec 9, 2018
  17. aakashmaji16
    Gingerbread Dec 9, 2018
    aakashmaji16 , Dec 9, 2018 :
    Can we get a google phone and pixel launcher support in the next update?
    As these two apps are not compatible with our phone but through update it would be compatible.
    Please consider this as a suggestion!
  18. Suketu d shah
    Donut Dec 9, 2018
    Suketu d shah , Dec 9, 2018 :
    after this update the batter drains without using the phone as well about 4 percentage per 30 min without even touching your phone. is everyone facing same problem??
    Arko Mustafi and Saish_B like this.
  19. K1541939756962
    Eclair Dec 9, 2018
  20. Xepher
    Eclair Dec 9, 2018
    eskimosound likes this.
