203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. ChiranthAtharvaa
    Gingerbread Aug 10, 2019
    ChiranthAtharvaa , Aug 10, 2019 :
    that's great, I'm getting only 4.5 hrs of SOT .
  2. Aziz_Amin_Oneplus
    Jelly Bean Aug 10, 2019
    Aziz_Amin_Oneplus , Aug 10, 2019 :
    Try to use your phone with minimum things, do not open things when in use, keep the background processes which you need, keep the brightness at minimum level, open location when needed, turn off Google backup, close all battery optimizations functions, keep the data on 3G and Wipe cache from recovery mode and then see the result.
    ChiranthAtharvaa likes this.
  3. Shadink
    Shadink , Aug 10, 2019 :
    I don't think clearing Cache (which became a useless trend) will solve the problem. Just let the update settle, give it a few days.
    Clearing Cache will make your phone make more effort in opening Apps and result in low battery performamce.
  4. antonio ray
    Cupcake Aug 10, 2019
    antonio ray , Aug 10, 2019 :
    A parte la batteria qualcuno ha riscontrato i famosi rallentamenti nello scrolling? Se potete rispondete
  5. G_surender_ramanakrishna
    Eclair Aug 10, 2019
    G_surender_ramanakrishna , Aug 10, 2019 :
    hi all
    still I haven't received this update till now even though I am using VPN
    please do the needful and also i have installed oxygen updater then also we havent get the updates
  6. haykarm
    Eclair Aug 10, 2019
    Mekanik97 likes this.
  7. Udaya_Chendur
    Honeycomb Aug 10, 2019
    Udaya_Chendur , Aug 10, 2019 :
    Won't this UI be scrapped when you roll back?
  8. danishdaycare
    Ice Cream Sandwich Aug 10, 2019
    danishdaycare , Aug 10, 2019 :
    Or use your phone like a normal person and just charge it 30 minutes when needed.... It's a smartphone.;)
  9. Aziz_Amin_Oneplus
    You can download the new Oxygen system update from apk mirror as you have downloaded the 9.0.8 update no need to roll back or do anything else.
  10. Aziz_Amin_Oneplus
    Well 30 minutes will give you 55% at most, I prefer charging it to 97% Everytime and use it normally and get around 7 hours of screen usage with 2 days battery life.
  11. Udaya_Chendur
    Am speaking about the new system updater UI which was in the last beta build.
    I saw that some users with stable build having the system updater UI that was available in beta builds.
    Just curious.
  12. M1565436996115
    M1565436996115 , Aug 10, 2019 :
    I started getting a new problem after a recent update. My phone automatically goes to to the silent or DND mode even though the slider is in Ring mode or Vibrate mode.
    This is happening after the recent updates.
    I don't think it as a hardware issue as no damage happened to the phone before this issue started happening
    Please help it is really frustrating to miss too many important calls because of this.
  13. Aziz_Amin_Oneplus
  14. Udaya_Chendur
  15. Aziz_Amin_Oneplus
    Your welcome [e]1f60a[/e]
    udayachendur likes this.
  16. lunchboxLarry
    Kum1r likes this.
  17. eye842
    Lollipop Aug 10, 2019
  18. saiSumanth1+
  19. saiSumanth1+
  20. Paul_W_
    Paul_W_ , Aug 10, 2019 :
    We'd soon know about it if they were. :p
