203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. Waveform Modifier
    Marshmallow Aug 13, 2019
    Waveform Modifier , Aug 13, 2019 :
    That is subjective. You need to find out for yourself.
  2. Kbzaloka
    Froyo Aug 13, 2019
    Kbzaloka , Aug 13, 2019 :
    I have a problem/bug. The WiFi disconnects me or sometimes it does not indicate that there is no Internet, I have to turn off it and then turn it on, to make it work again.
    Does anyone have that problem?
  3. Mustasim
    Ice Cream Sandwich Aug 13, 2019
    Mustasim , Aug 13, 2019 :
    pl go to wifi settings and check back this option. i hope this is it.
    Chungtd likes this.
  4. Kbzaloka
    Froyo Aug 13, 2019
    I have the option disabled, but this problem began to happen to me recently, and it is not the wifi because it only happens to me
  5. goparaju
    Donut Aug 13, 2019
  6. Waveform Modifier
  7. raffi.zainudin
    Eclair Aug 13, 2019
  8. goparaju
    Donut Aug 13, 2019
  9. goparaju
    Donut Aug 13, 2019
  10. Arun More
    Cupcake Aug 13, 2019
  11. goparaju
    Donut Aug 13, 2019
  12. Waveform Modifier
    Basically an app to force people with smartphone addiction to not be able to use their phone and lock them out for a specific amount of time.
  13. ninja123456
    ninja123456 , Aug 13, 2019 :
    open this post on the website. you can see there's a link in my signature. head over to the website which says how to get screen recorder. you can find your zenmode in the same place. same video applies for both options.
  14. Maurizio_it_TR
    Froyo Aug 13, 2019
    Maurizio_it_TR , Aug 13, 2019 :
    I am happy that you want to help users, but if they learned to read before writing it would certainly be better, and it would not be stressful to see the same requests 10/100/1000 times, if I have a problem, I read it first and if I can't find an answer, I look for help
  15. Ced357
    Eclair Aug 13, 2019
  16. S1518346025731
    Eclair Aug 13, 2019
    S1518346025731 , Aug 13, 2019 :
    I guess yes.. Battery drain issue is rectified.. I am using the phone with the new update for 2nd day and battery is now not draining the way it was during version 9.0.7
  17. S1518346025731
    Eclair Aug 13, 2019
    Can anyone help me as to how to enable and configure Zen mode.. I am not able to find it in settings.
  18. Mr_Cyrox
    KitKat Aug 13, 2019
    Mr_Cyrox , Aug 13, 2019 :
    Read the thread
    Instructions already where said many times already
  19. Tabzul nikhil
  20. Waveform Modifier
    That requires the part of the brain no one seems to be able to use.
    Arnab_1997 likes this.
