203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. fajarlc86
    Cupcake Aug 21, 2019
    fajarlc86 , Aug 21, 2019 :
    anyone can explain this? it did fast charging, then suddenly the current drop until almost didn't charge.. until i unplug the type c cable and the plug it again, charge going normal again..
  2. tungst5n
    Gingerbread Aug 21, 2019
    tungst5n , Aug 21, 2019 :
    Anyone had any change in signal [e]1f4f6[/e] with T Mobile after this update? Just curious.
  3. ninja123456
    Ice Cream Sandwich Aug 21, 2019
    ninja123456 , Aug 21, 2019 :
    it happens if the phone is heated. the phone charges slowly until the battery temperature is stable then it charges rapidly again. happens when battery sucking apps are running while charging
  4. fajarlc86
    so, do i have to close all app in background? or charge it in airplane mode?
  5. G_Sanchit_Bhatnagar_dSYB
  6. tungst5n
    Go to Settings and then Display. Then scroll down.
  7. ninja123456
    just the apps that suck too much cpu+GPU power like pubg etc
  8. ninja123456
    zenmode is set to max=min 20 min by default. you can't change it. what you can change is the notification you get quick suggests you to switch to zenmode after so and so time. that's all you can do
  9. G_Sanchit_Bhatnagar_dSYB
    G_Sanchit_Bhatnagar_dSYB , Aug 21, 2019 :
    Well yeah, that I can see but the Change log in the post said otherwise.
  10. ninja123456
    they haven't mentioned that in particular maybe they forgot to include "notification" somewhere in there.
  11. slmnanwr
  12. shadabaltamash
    Eclair Aug 21, 2019
  13. Waveform Modifier
    Marshmallow Aug 21, 2019
  14. shadabaltamash
    Eclair Aug 21, 2019
    shadabaltamash , Aug 21, 2019 :
    nope !! additional timing setting is not there!!
  15. Waveform Modifier
  16. shadabaltamash
    Eclair Aug 21, 2019
  17. Waveform Modifier
  18. ninja123456
    Ice Cream Sandwich Aug 22, 2019
  19. ninja123456
    ninja123456 , Aug 22, 2019 :
    I have reported this zenmode issue let's see if they even decide to give a damn about it.
  20. Hebbnag
    Gingerbread Aug 22, 2019
