203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. ninja123456
    Ice Cream Sandwich Sep 21, 2019
    ninja123456 , Sep 21, 2019 :
    according to manu j and David y there will be announcement on Android 10 update release for older devices in the global launch event in London that's on October 10th. this is mentioned in the first comment of android 10 release post for OnePlus 7. so have to wait and see what's what and whens when
    pkayop5t and Nikkhil like this.
  2. munikumar2003
    Eclair Sep 21, 2019
    munikumar2003 , Sep 21, 2019 :
    in network section prepared network LTE is not available...so JIO and other LTE networks are not working in OnePlus 5t
  3. Waveform Modifier
    Marshmallow Sep 21, 2019
    Waveform Modifier , Sep 21, 2019 :
    When it is ready ™
    nikunjmall likes this.
  4. mohanandhu
    Cupcake Sep 22, 2019
  5. mohanandhu
    mohanandhu , Sep 22, 2019 :
    is there any solution for this
  6. Waveform Modifier
    Marshmallow Sep 22, 2019
    Waveform Modifier , Sep 22, 2019 :
    Use the forum as it is intended. Go search. This had been answered.
  7. mohanandhu
    from where......I can't get plz brief clearly
  8. Waveform Modifier
    Use Google. This forum have a search function. Use them.
  9. mohanandhu
    plz guide me bro
  10. M1518072311335
    Froyo Sep 22, 2019
    M1518072311335 , Sep 22, 2019 :
    I am ready to wait for ages, but when you release the android 10 for 5 and 5t, please make sure it is not as buggy as pie, and you won't have to release a hotfix like OOS 9
  11. Waveform Modifier
    You clearly have no idea what you are talking about.
  12. M1518072311335
    Froyo Sep 22, 2019
    I clearly have idea what I am talking about, I deferred to use pie untill 9.0.8 amd was on android oreo just because it was laggy..hence as compared with the previous versions of OOS for op 5t atleast OOS 9 sucked, and don't want that to happen in OOS 10
  13. Waveform Modifier
    No. Pretty sure you have no idea how coding works. Otherwise, you would spill that BS here. Ignorant much?
  14. M1518072311335
    Froyo Sep 22, 2019
    That's correct, I am into finance, and have zero idea of coding and all, but I only expect my apps running smooth, and not too freeze often, that's all..I think that's a realistic expectation to have, atleast from the brand like One Plus.
  15. Waveform Modifier
    What about "brand like OnePlus"? They are peanut in the tech industry. Plus, no software is and never will be perfect. Nothing will ever be bug free and no software will be 100% smooth. Therefore, your statement is utterly ignorant and dumb.
  16. slmnanwr
    Gingerbread Sep 22, 2019
    slmnanwr , Sep 22, 2019 :
    As far as the screenshot is concerned, it looks like VoLTE is already enabled on your device. Those three are indeed the default options available on any similar OnePlus device, and LTE is a seperate toggle at the bottom of the list. Low speed or intermittent connectivity aren't always a problem of an absent LTE connection; they might as well be dependent on where you are and how good the range is. Cheers.
  17. ninja123456
    Ice Cream Sandwich Sep 22, 2019
    ninja123456 , Sep 22, 2019 :
    same software behaves differently on different hardware of same specification. this is one of the reason why more number of devices will be tested instead of just one before every update release. Google itself keeps fixing the bugs reported by various users throughout the year. once they develop new version of android they move on. no android will ever be bug free. same applies to every manufacturers. hope this isn't one of those arrogant replies and hope you have understood. less resources will be allotted to older devices and hence less planning and less bug fixes. a company's main intentions are that people keep buying new devices so that their business is afloat always. trying to make the old devices a "gem" will only hurt them.
    M1518072311335 likes this.
  18. versuchstier
    Eclair Sep 22, 2019
    versuchstier , Sep 22, 2019 :
    Not releasing a HotFix and keeping the 8 week release cycle for me sounds more dump and ignorant... It's not hard to fix that, but it's an active political decision not to fix the problem now or in an adequate time, instead on next release. And that is far away from Community driven.
    This software release is really awful, loosing bunch of data, because apps keeps crashing in the background. That's an unacceptable situation in my option.
    It's not bashing or disrespectful against you, Waveform Modifier I understand your point of view. But as software developer I see that's some things working against customers, and OnePlus should listen to them, not ignoring them. Maybe two Phones a year are too much too Handle for that "peanut".
    Edgar Palau and zerosixteen like this.
  19. Mr_Cyrox
    KitKat Sep 22, 2019
    Mr_Cyrox , Sep 22, 2019 :
    Once the 7T releases OnePlus will be supporting 7 different models (not counting the special 5G and other variants)
    So I don't think it's 2 phones...
    I get your post but I have to disagree sence I don't experience what you described here:
    If there is no bug there will be no hotfix naturally
    If there was an issue with the update most people would be facing said issue
    OnePlus 5/5T are already past 2 year mark (5T folows 5 update deadlines) and get basic updates (security patch)
    Thankfully we will get 10 still and I'm looking forward to it and I believe it will be faster then Pie release last year sence OnePlus 7 series just got it yesterday on stable
    rajat0409 and Waveform Modifier like this.
  20. X1565852932542
