203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. Mr_Cyrox
    KitKat Aug 8, 2019
    Mr_Cyrox , Aug 8, 2019 :
    OnePlus forums: WHERE ARE THE ONEPLUS 5/5T UPDATES????
    OnePlus: Releases update faster then OnePlus 6/6T
    OnePlus forums: WOW ONEPLUS! HOW COULD YOU GIVE AN UPDATE FASTER TO AN OLDER DEVICE AND DISAPPOINT NEW MODEL USERS!!!!!1!
  2. DogeAlpha
    Honeycomb Aug 8, 2019
    DogeAlpha , Aug 8, 2019 :
    You can download the latest "OnePlus system update" app from apk mirror
    Install it just like a regular app from outside the play store. Should be version 2.0.1.something
    After you got it installed, you will instantly see the change.
  3. LegolasX
    Jelly Bean Aug 8, 2019
    LegolasX , Aug 8, 2019 :
    there are different forum members for different devices.
    they managed to push updates for 4 devices along with beta for 2 devices in two days.
    what made them stop for on pushing stable for 6/6T..makes me think.
    RandomUserOne likes this.
  4. Mr_Cyrox
    KitKat Aug 8, 2019
    Idk,
    Not really up to date what is happening with other devices but that is what I've seen so far on this thread being posted...
    If they did hold the update then it must be for some last minute bug that they must have discovered or something...
  5. DogeAlpha
    Oneplus schedule be like: one update to stable branch every one-two months
    5/5T : 2 updates within 3 weeks.
    Also, it's ironical how we got the same update as the 6/6T users from open beta while we are on stable:rolleyes:
  6. Buckybakth
    Eclair Aug 8, 2019
    Buckybakth , Aug 8, 2019 :
    thanks mate , i checked but there are only two versions available in apk mirror
    1.8.3 & 1.0.6 ,
    I'll wait for the stable version comes but less bugs
  7. Aziz_Amin_Oneplus
    Aziz_Amin_Oneplus , Aug 8, 2019 :
    It's not necessary that if changelog is same then update would also be the same, OnePlus 5 and 5T 9.0.8 update is made as stable and OnePlus 6 and 6t 16 and 24 update is made as open beta, and other things now the situation is like Open beta Performance looks very promising so they would had mix it to give better and good update for both.
  8. nguyenphong108
    Eclair Aug 8, 2019
  9. Rarnob
    Cupcake Aug 8, 2019
    Ewiii likes this.
  10. DogeAlpha
    I know what you are talking about. Wrong app mate
    You found "System Updates"
    I said "OnePlus System Update"
    You probably got that result because you typed updateS with an S at the end.
    Try again without the S in the end.
    You should find it. App icon looks exactly like OnePlus settings icon
  11. Buckybakth
    Eclair Aug 8, 2019
    DogeAlpha
    You should find it. App icon looks exactly like OnePlus settings icon​
    My fault Dude , got it now , i was checking page by page , forget to search by name ..now i download . thanks for helping me out
  12. F1564981056899
    Cupcake Aug 8, 2019
    O1564627422275 likes this.
  13. Naren2167
    Froyo Aug 8, 2019
    Naren2167 , Aug 8, 2019 :
    my op5 was draining battery too fast after 9.0.7 update...hope this update will fix that...
  14. viteq
    Donut Aug 8, 2019
    viteq , Aug 8, 2019 :
    It's all great but is there any chance that future updates will bring back "Do not disturb" to the slider? Or an option to choose between DND and vibration? Since it was changed I don't use the slider at all.
    Hj2396 likes this.
  15. ninja123456
    Ice Cream Sandwich Aug 8, 2019
    ninja123456 , Aug 8, 2019 :
    don't get too excited. there was some security issue efficient should be fixed with security patch that's the reason they updated all their devices as early as possible and they don't want to crash their servers so they went with incremental as usual. they didn't have any plans until 30 days from now for OnePlus 5
    Paul_W_ likes this.
  16. Aziz_Amin_Oneplus
    Well yes you are right, Qualcomm just announced a bug which have hit their old and new chipsets, but I am thinking why OnePlus 6 and 6t stable version is not updated as others are done with it?
    Paul_W_ likes this.
  17. onoffbot
    Froyo Aug 8, 2019
    onoffbot , Aug 8, 2019 :
    1:1 фото режим не работает .. только у меня это ??? или ещё есть у кого ?
  18. nofoo
    Froyo Aug 8, 2019
    nofoo , Aug 8, 2019 :
    Good to see zenmode comming from beta to stable. Now i'm hoping for digital wellbeing to be ported next. DW is the thing i am missing most since i went back to stable builds.
  19. sundeepkrtiwari
    Froyo Aug 8, 2019
  20. venioni
    Froyo Aug 8, 2019
