203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. needa
    Honeycomb Oct 14, 2019
    needa , Oct 14, 2019 :
    Yeah kinda sorta. We got Pie at the end of Feb. It got fixed enough for people to use in April. Then the 3 got it soon after that.
    Fast forward a bit and the 6 is getting 10 this month and we are still having to wait till q2. And at the same time we have the Project whatever it's called that is supposed to make it quicker to update.
    I figure it's one of two things. We are waiting on drivers or OnePlus wants us to buy new phones. Most likely the latter.
    "Focused on newer devices" is a copout. 10 is done. No more devices till summer.
    nofoo likes this.
  2. G_balayya_389_TPpI
    Eclair Oct 14, 2019
    G_balayya_389_TPpI , Oct 14, 2019 :
    I guess if we get Android 10 in June/July 2020 , device will reach eol around November , and that's end of 5t I guess
    I guess I will switch to lineage os after that ,
    fostel likes this.
  3. G_balayya_389_TPpI
    Eclair Oct 14, 2019
    did u try reinstalling the os
  4. S1571001720147
    Cupcake Oct 14, 2019
    S1571001720147 , via OnePlus 5 , Oct 14, 2019 :
    yes, I've try that. But now, it's come back normal again. I just hit the camera lens with the magnet and open camera app. then, wooaah, it's solved.
  5. harshitdhoot
    Eclair Oct 14, 2019
    harshitdhoot , Oct 14, 2019 :
    Please enable equilizer settings for Bluetooth earphones in oneplus 5. I am unable to make on audio switch in audio tuner to use equilizer settings. Please fix this as sson as possible.
    Thanks
  6. Q1545504703112
    Q1545504703112 , via OnePlus 5 , Oct 14, 2019 :
    Never gonna happen
  7. Waveform Modifier
    Marshmallow Oct 14, 2019
    Waveform Modifier , Oct 14, 2019 :
    No. 100% unlikely
  8. omarmawal
    Gingerbread Oct 15, 2019
  9. Waveform Modifier
    Marshmallow Oct 15, 2019
  10. Natarajanvaidhy
  11. Silver_
    Silver_ , via OnePlus 5T , Oct 15, 2019 :
    week 304 update says OnePlus 5/T are set to recieve some update in the comming few weeks. I don't expect it to be much. (maybe just a security patch or so)
  12. Natarajanvaidhy
    Natarajanvaidhy , via OnePlus 5 , Oct 15, 2019 :
    As per update schedule, 5/T to get bimonthly updates, hence it's already due with security patch upto 30th September.
  13. nick_k
    nick_k , Oct 15, 2019 :
    No security patches for 2+ months, Android 10 after 6 months (and more), when cheaper phones like HMD's Nokia models already receiving Android 10.
    Well done and never settle 1+ :rolleyes::rolleyes::rolleyes:
    nofoo likes this.
  14. Pierre02
    Honeycomb Oct 15, 2019
    Pierre02 , via OnePlus 5 , Oct 15, 2019 :
    Cheaper but newer
  15. Hitman_047
    Froyo Oct 15, 2019
  16. paulomodesto , via OnePlus 5T Midnight Black , Oct 15, 2019 :
    They are taking to Long to bring this 2 month OTA!
    If it's only latest Google security patch, don't Know why the waiting...
    Hope finally we will receive an build higher than latest Open Beta, so I can dirty flash over my Open Beta build so I don't lose all my data and configs!
    OnePlus, Be Aware!
    Realme X2 Pro is here to haunt you!!!
    • 6.5-inch (2400 x 1080 pixels) Full HD+ 20:9 aspect ratio Fluid AMOLED 2.5D curved glass display with 90Hz refresh rate, HDR10+, 100% DCI -P3 color gamut, Corning Gorilla Glass 5 Protection
    • Octa-Core Snapdragon 855 Plus (1 x Kryo 485 at 2.96GHz + 3 x Kryo 485 at 2.42GHz + 4 x Kryo 385 at 1.8GHz) 7nm Mobile Platform with 675MHz Adreno 640 GPU
    • 6GB LPDDR4X RAM with 64GB (UFS 3.0) / 8GB LPDDR4X RAM with 128GB (UFS 3.0) / 12GB LPDDR4X RAM with 256GB (UFS 3.0) storage
    • Android 9.0 (Pie) with ColorOS
    • Dual SIM
    • 64MP rear camera with 1/1.72″ Samsung GW1 sensor, 0.8μm pixel size, f/1.8 aperture, LED flash, EIS, 13MP Telephoto lens with 1/3.4″ sensor, 1μm pixel size, f/2.5 aperture for up to 20x hybrid zoom, 2.5cm macro, 8MP 115° 1/3.13″ ultra-wide angle lens with 1.4μm pixel size, f/2.2 aperture, 2MP depth sensor with f/2.4 aperture,1.75μm pixel size, 960fps slow-motion
    • 16MP front-facing camera with Sony IMX471 sensor, f/2.0 aperture, 1.0μm pixel size
    • In-display fingerprint sensor
    • 3.5mm audio jack, Stereo Speakers, Dolby Atmos
    • 4G VoLTE, WiFi 802.11 ac (2.4GHz + 5GHz) 2×2 MIMO, Bluetooth 5, GPS, GLONASS, USB Type-C
    • Dimensions: 161×75.7×8.7mm; Weight: 199g
    • 4000mAh battery (typical) / 3920mAh (minimum) with 50W (10W/5A) SuperVOOC fast charging
  17. Waveform Modifier
  18. Pierre02
    Pierre02 , Oct 15, 2019 :
    Good luck with updates on that phone!
  19. Pierre02
    October patches and maybe some beta features like new screenshots or digital wellbeing
  20. Mohta.am likes this.
