203
OxygenOS 9.0.8 OTA for OP5 & OP5T
  1. Waveform Modifier
    Marshmallow Jan 25, 2020
    Waveform Modifier , Jan 25, 2020 :
    It's already disconnected when you discount. Please read the thread. It's already explained.
  2. JamesBoulder
    Gingerbread Jan 25, 2020
    JamesBoulder , via OnePlus 5T , Jan 25, 2020 :
    The moment you press the End Call button, the call is disconnected. You should ignore the notification after you have ended the call. It is just a small bug, no need to worry, it will be fixed in upcoming updates.
    Sakib748 likes this.
  3. G_Rahul_Pathak_TYQV
    Cupcake Mar 13, 2020
    G_Rahul_Pathak_TYQV , Mar 13, 2020 :
    Can anyone help me to remove beta version and install the main OS
    as I am using beta, latest version update not available and facing some issue with my phone.. please help.share any link or any guidelines..
  4. Waveform Modifier
    Marshmallow Mar 13, 2020
    Waveform Modifier , Mar 13, 2020 :
    Beta related questions and comments should be directed in the beta thread. Let alone the instructions is in every beta thread across multiple forum on this site.
  5. saivenkatsingh
    Eclair Mar 29, 2020 at 12:12 PM
    saivenkatsingh , via OnePlus 5T , Mar 29, 2020 at 12:12 PM :
    install the OnePlus updater app from playstore and select the update method to full update and download the zip keep the file on the storage and go to the local update and select the zip file and it's done after that while turning on your phone perform the total data wipe and also cache.make sure all the data is backed up before doing this ...
