225
OxygenOS 9.0.9 OTA for the OnePlus 5 and OnePlus 5T
  1. Anand PM
    Honeycomb Oct 19, 2019
    Anand PM , via OnePlus 5 , Oct 19, 2019 :
    Calling out all the unlucky ones who is still carrying a Oneplus 5, did any of you notice issues with EIS in the Camera?
    Like 'THERE IS NO EIS ANYMORE' ?
    On the older version of Oneplus camera, i guess we had a drastic improvement in the output video in terms of stability.
    And btw if any of you had never downloaded apk of Oneplus Camera App from Third party websites please tell me the current version number of the Camera app you have.
    I'm confused if i downloaded the release for other Oneplus phones with OIS i might run into a version of the apk with no EIS right? I donno...
    Thanks and hope to hear from some of you...
    G_jagdish_dash_KZbn likes this.
  2. Malhotra_H
    Cupcake Oct 19, 2019
    Malhotra_H , via OnePlus 5T , Oct 19, 2019 :
    Its 20th fourth day of the new version launch l,I didn't get it on my phone,last time when I use the flash memory my data got corrupt.My Question is,Is this a staged unit or you just stopped giving the update?
  3. Waveform Modifier
    Marshmallow Oct 19, 2019
    Waveform Modifier , Oct 19, 2019 :
    No one here controls the update.
    Mustasim likes this.
  4. ajaj attar
    Cupcake Oct 20, 2019
    ajaj attar , Oct 20, 2019 :
    its 9.0.8 on my one plus 5 and facing terrible battery draining issues.. i cleared catches from recovery mode.. it won't work.. plz suggest something
    KostasPal likes this.
  5. Waveform Modifier
    Marshmallow Oct 20, 2019
    Waveform Modifier , Oct 20, 2019 :
    Look at your apps. You have to do some investigating as to what is causing it.
  6. ajaj attar
    thank you for the reply. how do u suggest i should do it?
  7. Waveform Modifier
  8. vishnuvardhanv
  9. needa
    Honeycomb Oct 20, 2019
    needa , Oct 20, 2019 :
    Maybe go to battery and check out high app usage. Go to data and see if any that you aren't using much are eating data. Maybe between the two you can find some rogue apps. Dunno 4sure.
  10. Shubham Gujjar
  11. G1527673663432
    Donut Oct 20, 2019
  12. Mishra1995
    Mishra1995 , Oct 20, 2019 :
    Since last 2 day my OnePlus 5 is going automatically to silent mode, despite of being alert slider in ring mode. Already tried factory reset and manually installing latest firmware. Any suggestion??
  13. chhatrapalsingh8
  14. Z1562699975568
  15. JACK CITY
    Donut Oct 20, 2019
    JACK CITY , Oct 20, 2019 :
    Should I upgrade from the beta? Betas been doing me good but Idk is this stable better or no?
  16. ninja123456 , via OnePlus 5 Midnight Black , Oct 20, 2019 :
    wait for few more days it will arrive. if it doesn't then download the full rom from OnePlus website and flash when it arrives
  17. vikas6921
    vikas6921 , via OnePlus 5 , Oct 20, 2019 :
    Hey Guys,
    Did anyone facing the issue after upgrading this recent patch?
    I started facing first time issue with my SIM card. I am using both the SIM slot and it used to work perfectly earlier this upgrade but after upgrade I can use any one of SIM.
    Any input/ suggestion would be highly appreciated.
    Thanks,
    Vikas
  18. Mdeepak307
    Donut Oct 20, 2019
  19. harish.nani451
  20. Waveform Modifier
    There is no set days. (ever)
