225
OxygenOS 9.0.9 OTA for the OnePlus 5 and OnePlus 5T
  1. Joeri Wong
    Eclair Oct 20, 2019
    U1516964462975 likes this.
  2. V1571585652123
    Cupcake Oct 20, 2019
    V1571585652123 , Oct 20, 2019 :
    Hi.
    I did not allow 'contacts' acces to sms, place etc which I now regret. How do I change that?
    Best wishes,
    Lars
  3. andreacos92
    Gingerbread Oct 20, 2019
    andreacos92 , Oct 20, 2019 :
    Not really lol
    Settings - Apps - Show all apps - Contacts - Permissions
    V1571585652123 likes this.
  4. M1548410046405
  5. M1548410046405
  6. M1548410046405
  7. needa
    Honeycomb Oct 20, 2019
    needa , Oct 20, 2019 :
    Same thing was happening to me months ago. Eventually it stopped. Can't remember why or how. I'll see if I can find my posts about it and if I said what fixed it, I'll get back to ya.
    K. I did find the fix. It kept happening to me when the phone went into doze. I turned off doze and it stopped happening. A couple of days later I turned it back on. No issues since.
    https://forums.oneplus.com/threads/...thout-moving-the-slider.627998/#post-16821057
    Mishra1995 likes this.
  8. M1548410046405
  9. M1548410046405
    M1548410046405 , Oct 20, 2019 :
    [QUOTE = "needa, post: 20931668, membro: 100928"] La stessa cosa mi stava succedendo mesi fa. Alla fine si è fermato. Non ricordo perché o come. Vedrò se riesco a trovare i miei post al riguardo e se ho detto cosa lo ha risolto, torno da te.
    K. Ho trovato la soluzione. Continuava a succedermi quando il telefono è sonnecchiato. Ho spento il sonnellino e ha smesso di succedere. Un paio di giorni dopo l'ho riacceso. Nessun problema da allora.
    https://forums.oneplus.com/threads/...thout-moving-the-slider.627998/#post-16821057 [/ QUOTE]
    Io non parlo della modalità silenziosa...a me capitano delle balbuzie nell uso normale del telefono...dei rallentamenti del software.....nello scorrere nel menu .....forse un calo di framerate
  10. V1533008503768
  11. kr.rahul27
  12. joncharmed93
  13. M1570656784096
    MarcoMicale and goparaju like this.
  14. goparaju
    Donut Oct 20, 2019
    MarcoMicale likes this.
  15. RegiP
    Froyo Oct 20, 2019
  16. dsw28
    Marshmallow Oct 20, 2019
    dsw28 , Oct 20, 2019 :
    read and understand the first post
    stark2991_PL likes this.
  17. Shadink
    Shadink , Oct 20, 2019 :
    As soon as possible by Q2 2020
    Vamsic likes this.
  18. Waveform Modifier
  19. iNathan
    Gingerbread Oct 21, 2019
    iNathan , Oct 21, 2019 :
    The problem is you've not waited long enough.
    //No Sarcasm, actually just wait. It's an incremental roll out.
  20. U1516964462975
    Donut Oct 21, 2019
