225
OxygenOS 9.0.9 OTA for the OnePlus 5 and OnePlus 5T
  1. Jontalk5
    Gingerbread Oct 24, 2019
    Jontalk5 , Oct 24, 2019 :
    Crazy....how many apps are installed on your phone and what type? I updated to 9.0.9 and am having none of these problems on my 5T. Most everyone that has problems owns a phone loaded with tons of apps which drag the performance and create problems. You might think about uninstalling many of them, clear the cache then add them back one a time to see which is the culprit :) I have zero social media or gaming apps on my phone in case you're wondering
  2. Deactivated User
    Oct 24, 2019
    stark2991_PL likes this.
  3. mfswisher
    Cupcake Oct 24, 2019
    mfswisher , Oct 24, 2019 :
    mine keeps freezing to the point I have to hard restart. no issue before the October update.
    vinayvinayak62682 likes this.
  4. T1533998691666
    T1533998691666 , via OnePlus 5 , Oct 24, 2019 :
    Hopefully it doesn't come back in Android 10
  5. Q1545504703112
    Honeycomb Oct 24, 2019
    Q1545504703112 , via OnePlus 5 , Oct 24, 2019 :
    It's weird because the lags were barely present for me in 9.0.8 but now they are worse than ever after this update
    Yash_Gohan and vinayvinayak62682 like this.
  6. piyushdt
  7. priteshjain
  8. npmsaha
  9. T1533998691666
    Can u post more details about your problem here? E. G. What TV brand, how many inches, what casting app are you using, wifi speed, wifi router model etc. So that we may figure out the problem.
  10. Mr_Cyrox
    KitKat Oct 24, 2019
    Mr_Cyrox , Oct 24, 2019 :
    How about you tell us
  11. I1571894469592
    I1571894469592 , Oct 24, 2019 :
    The battery life still has not improved after a full drain and full overnight charge. Still getting fast discharge.
    Does anyone have more tips? Is it possible to roll back, if it continues like this?
  12. T1533998691666
    Go download the 9.0.8 in OnePlus website while it's still avaliable.
  13. priteshjain
    priteshjain , via OnePlus 5 , Oct 24, 2019 :
    TV Brand - VU premium android 43 inch
    Router & Modem - Mi Router Mini 802.11 ac dual band
    On my mobile i got wifi 8 to 9 Mbps download speed
    that's it
  14. M1511272253663
    M1511272253663 , Oct 24, 2019 :
    Very few. About 20. I have never had a problem with an other ota update.
  15. M1511272253663
  16. stark2991_PL
    KitKat Oct 24, 2019
    stark2991_PL , Oct 24, 2019 :
    Do a factory reset. There's no need to go back to the older version, since the last one is working fine. I'm getting 7hrs SoT on the 9.0.9.
    You should do a factory reset too.
  17. M1511272253663
    If I do a factory reset I will have to reinstall all the apps and all the data etc. Who has time for this? It's like a car after a service saying oh you have to dismantle the engine.
    Mobile phone makers should stop using this as a 'fixing' mechanism.
  18. Waveform Modifier
    Marshmallow Oct 24, 2019
    Waveform Modifier , Oct 24, 2019 :
    Well than, good thing that there is no one here that is from said mobile phone maker than.
  19. Mr_Cyrox
    KitKat Oct 24, 2019
    That was an advice not a requirement that you must do else your phone will break down
    What was the last time you Factory reset your device?
  20. M1511272253663
    With this one never. Had zero problems until I now.
