225
OxygenOS 9.0.9 OTA for the OnePlus 5 and OnePlus 5T
  1. Waveform Modifier
    Marshmallow Nov 5, 2019
    Waveform Modifier , Nov 5, 2019 :
    That's the current version.
    Rudy102 likes this.
  2. T1533998691666
    Gingerbread Nov 5, 2019
  3. M1548410046405
    Cupcake Nov 5, 2019
    M1548410046405 , Nov 5, 2019 :
    Dopo aver riscontrato ancora i ritardi della UI con Android 9 (con Oreo mai un problema) ho mandato il mio Op5t in assistenza...hanno sostituito la scheda madre....oggi mi è stato restituito il telefono e pochi minuti fa si sono ripresentati i rallentamenti....cosa posso fare?
  4. M1548410046405
    Cupcake Nov 5, 2019
  5. Waveform Modifier
    Marshmallow Nov 6, 2019
    Waveform Modifier , Nov 6, 2019 :
    Last I checked this is an English forum
  6. Sh4dow17
    Cupcake Nov 6, 2019
  7. slmnanwr
    Gingerbread Nov 6, 2019
    slmnanwr , Nov 6, 2019 :
    Q2 2020 at the latest
  8. a.sayed
    Cupcake Nov 6, 2019
    a.sayed , Nov 6, 2019 :
    No
  9. ninja123456
    Ice Cream Sandwich Nov 6, 2019
  10. Y1508835174398
    Cupcake Nov 6, 2019
    Y1508835174398 , via OnePlus 5 , Nov 6, 2019 :
    dear team, after downloading this update it is draining the battery very fast, i feel the difference before and after, it says whatsapp is using high power and asking to force stop, chrome browser, Instagram are the same.
    please fix this asap.
    Thank You.
  11. Waveform Modifier
    There is no such thing as a team here.
  12. AgenteAlves
    Eclair Nov 6, 2019
    AgenteAlves , Nov 6, 2019 :
    same here...
    Y1508835174398 likes this.
  13. G1547898933853
    Cupcake Nov 6, 2019
    G1547898933853 , Nov 6, 2019 :
    Problem is with whatsapp. Install whatsapp beta and problem solved. Same happened here and it is OK now.
  14. Z1541217980568
    Cupcake Nov 6, 2019
    Z1541217980568 , Nov 6, 2019 :
    Having issues with parallel apps, same account of main app is redirected in parallel app as well when the parallel app is enabled and accessed.
    Eg : WhatsApp, Paytm
    Actually the parallel app should start from sign in landed ng page
  15. AgenteAlves
    Eclair Nov 6, 2019
    Hi have done a wipe cash from the recovery mode and the issue seems solved.
  16. antonio ray
    Cupcake Nov 6, 2019
    antonio ray , Nov 6, 2019 :
    I discovered that the system slowdowns occur when the screen is turned on for 1 hour ... then just turn off the screen and turn it back on and the slowdowns disappear ... does anyone have a permanent solution to the problem?
    yaswanth.p1 likes this.
  17. antonio ray
    Cupcake Nov 6, 2019
