225
OxygenOS 9.0.9 OTA for the OnePlus 5 and OnePlus 5T
  1. Waveform Modifier
    Marshmallow Jan 7, 2020
    Waveform Modifier , Jan 7, 2020 :
    Hahahahahahahahaha. F' no.
  2. Suraj gurav 007
    Ice Cream Sandwich Jan 7, 2020
    Suraj gurav 007 , via OnePlus 5 , Jan 7, 2020 :
    thanks bro..i want this type of ans..
    many others are making fool
    Siva Teja Reddy likes this.
  3. Waveform Modifier
    So, saying the truth is "making fool"? Good to know where your standards is at.
  4. Silver_
    Gingerbread Jan 7, 2020
    G_A_K_Kjgr likes this.
  5. danishdaycare
    danishdaycare , Jan 7, 2020 :
    Stand closer to your router. Do you honestly think an update decreased your wifi range?
    jdmori11 likes this.
  6. jdmori11
    Cupcake Jan 7, 2020
    jdmori11 , via OnePlus 5 , Jan 7, 2020 :
    but before update i was able to access it anywhere in my home and all other devices are working fine with wifi but my op5 only connects to wifi when i am in same room where my router is. if every other devices are good then problem is in my phone right. and i am also confused that how an update could decrease my wifi range but after watching this i have no other conclusion to make. as before update it was working fine.
  7. joncharmed93
  8. bpaterson
    Eclair Jan 7, 2020
    bpaterson , via OnePlus 5T , Jan 7, 2020 :
    Oneplus phones are a little goofy as to which band they choose to connect with. If your router has both 5GHz and 2.4GHz it is possible you used to connect on the 2.4GHz and are now connecting on the 5GHz band and experiencing range issues.
  9. jdmori11
    Cupcake Jan 7, 2020
    ok. but how to change the bandwidth on which my phone is connected i tried to search in settings but found nothing so i posted issue on community. if someone someone one shows me how to change it to 2.4 GHz it would be great help. thanks.
  10. G.Andrea
    Froyo Jan 7, 2020
    G.Andrea , via OnePlus 5T , Jan 7, 2020 :
    Yes, a software update can mess with WiFi range. A well optimized kernel, with the right modules inside, can improve or decrease your WiFi/Radio cellular capabilities.
    I don't think tho that it's this case, probably there is an issue at hardware level, like a damaged one.
  11. G.Andrea
    Froyo Jan 7, 2020
    You have to manually connect to the 5Ghz/2.5Ghz WiFi network. usually a dual band router has both of them and you can use each one selecting the desired one from WiFi networks menu in your phone. You have to enter your wifi password since you are connecting to a different network
  12. nguyenphong108
    nguyenphong108 , via OnePlus 5T , Jan 7, 2020 :
    perhaps oneplus is no longer interested in software, hok is only interested in profit.The smartphone is constantly out, the software is slow and nothing unexpected
    Siva Teja Reddy and Surya.Nivas like this.
  13. Maurizio_it_TR
    Froyo Jan 7, 2020
    Maurizio_it_TR , Jan 7, 2020 :
    Like all the others, with the difference that OP still gives support to products of 2/3 years ago (op3/t op5/t)
  14. danishdaycare
    Yeah, I meant wrecking ONE persons wifi range...
  15. DogeAlpha
    Honeycomb Jan 7, 2020
    DogeAlpha , Jan 7, 2020 :
    2. They could have added it with android pie, or earlier, or anytime they wanted. They didn't do it until now, they probably won't do it at all
    3. It's a beta feature on the newest phones. Unlikely to get it.
    4. Most likely getting it
    9 Ram boost/ smart boost. We are getting this for sure.
  16. zer0se7en
    zer0se7en , via OnePlus Community App , Jan 7, 2020 :
    5T is a 2yr old model. What are you expecting?
    7T having the first Android 10 out of the box before Pixel 4 was actually quite impressive. And was upgraded couole of times already.
  17. Yashvendra_Singh_Raghav
    Yashvendra_Singh_Raghav , via OnePlus 5 , Jan 7, 2020 :
    after april we can expect news about android 10 version
  18. joncharmed93 and Siva Teja Reddy like this.
  19. renanmontoro likes this.
  20. LizardSnake76
    Froyo Jan 7, 2020
