1290
OxygenOS 9.0 OTA for the OnePlus 6
  1. I1527342910048
    Froyo Sep 22, 2018
    Vladut123 likes this.
  2. F_Rushabh_Shah_King_mAWR
    Honeycomb Sep 22, 2018
  3. O1537625625933
    Cupcake Sep 22, 2018
  4. saivedavyas
    Eclair Sep 22, 2018
    saivedavyas , Sep 22, 2018 :
    thnq bro
  5. E1532675904874
    Eclair Sep 22, 2018
  6. I1527342910048
    Froyo Sep 22, 2018
  7. Deactivated User
    Sep 22, 2018
  8. Arun_R
    Gingerbread Sep 22, 2018
    Arun_R , Sep 22, 2018 :
    This update has not been rolled out to all the users yet. This OTA will have a staged rollout.
  9. B1530356799527
    B1530356799527 , Sep 22, 2018 :
    I haven't received the update of the OS yet. Is there a different procedure to be followed other than checking under 'system update'?
  10. Deactivated User
    Sep 22, 2018
  11. DevonT
    DevonT , Sep 22, 2018 :
    Some people have reported that apps in the Recents screen are blank white. I'm noticing the same issue now.
    Nothing's wrong with the app itself. It just shows itself as white until you tap on it.
  12. Arun_R
    no . you will have to wait
  13. Deactivated User
    Sep 22, 2018
  14. I1527342910048
    Froyo Sep 22, 2018
    I1527342910048 , Sep 22, 2018 :
    you can go for local upgrade...but won't suggest it .as it is mention in post..that may be some function won't work .
    baki chill ye saly 1-2 din mai denge update.
  15. Gauri11
    Eclair Sep 22, 2018
  16. tigerstrom
    Froyo Sep 22, 2018
    tigerstrom , Sep 22, 2018 :
    Or if you are in hurry download oxygen updater
  17. Deactivated User
    Sep 22, 2018
  18. Arun_R
    Using VPN to download this build might not work as therollout Is not based on regions and is randomly pushed out to a limited number of devices.
    You should wait
    E1512057564980 and Vladut123 like this.
  19. Kodavati suresh babu
    Eclair Sep 22, 2018
    Kodavati suresh babu , Sep 22, 2018 :
    wow great news, but last update to 5.1.11 I done through Oxygen OS updater App.. now when I am checking through regular OTA the upgrade information is not showing.
    and yes, the updates information is showing in Oxygen OS updater App to 9.0 pie.
    if I update their Oxygen OS updater App, will I not get OTA through regular settings menu... please advise
  20. Gauri11
    Eclair Sep 22, 2018
