1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. Syed Maaz Ali
    Eclair Sep 23, 2018
  2. GoranJ
    Eclair Sep 23, 2018
    GoranJ , Sep 23, 2018 :
    So, as most of yours screens, mine looks like this more often than I like it. As much as I try to understand staged roll out I have to point out that being an user friendly company OnePlus should really let it all out or keep it under wraps until everything is ready for everyone.
    By not doing so we have frustrated customers and not easy roll out.
    I don't mind testing. It's ok. But test it and than let us have it.
    Furthermore beta testing should really be more straightforward process. It is really crazy that you should commit to the test and then passing from beta to stable really you have to wipe and start from scratch.
    Thanks to this many customers that were thinking to test the Beta stayed out of it thus making this release frustratingly slow.
    Just saying...
    Vladut123 and utsav17 like this.
  3. Rajeev Rais
    Donut Sep 23, 2018
    Vladut123 likes this.
  4. utsav17
    Honeycomb Sep 23, 2018
    utsav17 , Sep 23, 2018 :
    why moving from beta to stable P via downgrading to oreo and then updating ?
    instead , why not download Android P stable ROM and then install directly ? it's possible right?
    so should i wait for android P stable download link or downgrade to oreo and then update ?
  5. utsav17
    agreed. report to feedback and twitter too.
  6. Rajeev Rais
    Donut Sep 23, 2018
    Rajeev Rais , Sep 23, 2018 :
    i m already on oreo i haven't downloaded the Android p beta so what i habe to do next to download the stable. original Android p?
  7. ujjwalk308
    Gingerbread Sep 23, 2018
    ujjwalk308 , Sep 23, 2018 :
    It's different. Open Beta 1 is the first version and Beta 3 is last.
  8. utsav17
    just wait for update
    Vladut123 and Rajeev Rais like this.
  9. deangilvin
    Jelly Bean Sep 23, 2018
    deangilvin , Sep 23, 2018 :
    You do realize that every single company does a staged rollout with updates, correct? One of the main reasons for this is if by chance the file gets corrupted or there is a problem with the file it has an effect on less devices than every single device in use.
    It's much easier for them to roll out a fix for a few hundred/thousand phones than it is for a million.
    To say nothing of the fact that they would have to secure servers all around the world capable of handling hundreds of thousands of people simultaneously downloading off the server.
    Prashant Kate and Vladut123 like this.
  10. ujjwalk308
    You'll get an OTA notification. That'll download and install the update. Or, you can use Oxygen Updater (play store) to download and install manually.
  11. manie329
    Cupcake Sep 23, 2018
  12. rachit_shah
    Eclair Sep 23, 2018
    rachit_shah , Sep 23, 2018 :
    Hello,
    I just updated my Op6 to android pie stable from Oreo
    Facing some issues. If others facing such issues then have u found any solution?
    Issues
    1. In dialer, whenever we cut a call, facing animation issues
    (they are kind of slow and seems to be annoying)
    2. Cache settings not available
    Attaching the following screenshots as per issues.
    1st screenshot clearly shows the animation issue which has a short delay. (Tried wiping cache from recovery after that also issue persist)
  13. F_Purvesh_Sankhla_ntOq
    F_Purvesh_Sankhla_ntOq , Sep 23, 2018 :
    I'm on beta 2 how to get the full upgrade the above link is not opening
  14. chazey2
    chazey2 , Sep 23, 2018 :
    You have received update good! Now you ask about 5/5T is this thread not congested enough with questions on when for OP6?
  15. AYYAPUSETTY JEEVAN KUMAR
  16. A1527488884631
    Froyo Sep 23, 2018
  17. chazey2
    What is so crazy it's clearly stated if you go beta path you will have to clear data to return to stable. Another who flashed and read later??
    Vladut123 and aditza like this.
  18. Neerajrocks
    Eclair Sep 23, 2018
    Neerajrocks , Sep 23, 2018 :
    Hi Guys can't wait for the OTA to enjoy the new update , just use the oxygen updater app ...
    Tutorial in link below.
  19. Rajeev Rais
    Donut Sep 23, 2018
  20. S1534822307917
