1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. Nik_jp
    Froyo Sep 23, 2018
    Nik_jp , Sep 23, 2018 :
    I've been using the stable version of Android Pie on my OP6 for two days now and it hasn't given me any problems. However I feel as though the new animations make the device feel slower as I done s general speed test with opening applications against another OP6 device running Oreo and the other device came ahead by a few seconds. not a big difference but definitely one that you can notice.
    Vladut123 likes this.
  2. Neerajrocks
    Eclair Sep 23, 2018
    Neerajrocks , Sep 23, 2018 :
    https://forums.oneplus.com/threads/oxygen-updater-app.594603/
    i have added above the link to forum for the app and there feedback for your quick reference.
    also to clarify the app does not makes the update ot just downloads the latest ota build so that you can update like you do when you receive an OTA through system updates in settings...
    i highly recommend it...but i am not 100% sure if its associated with oneplus or not!
    hope this helps you buddy!
  3. S1533735916536
    Donut Sep 23, 2018
    S1533735916536 , Sep 23, 2018 :
    Hi everyone.
    My device is running on openbeta 3 .And my device has not yet got stable pie update.Do I have to come to stable oxygen os to get the update.
  4. dhaval24
    Froyo Sep 23, 2018
    dhaval24 , Sep 23, 2018 :
    i have just updated Android pie and anyone having display brightness issues..ya m keen fo dis so download it from oxygen updater app coz of dat dis issues are arises...?
  5. Neerajrocks
    Eclair Sep 23, 2018
    Yes you have to roll back to get the ota update...
  6. Jay_Trivedi
    Froyo Sep 23, 2018
    Jay_Trivedi , Sep 23, 2018 :
    nope man unless they released to other ppl. I done op3 to stable for update but got no update
  7. F1534389321621
    Eclair Sep 23, 2018
  8. S1533735916536
    Donut Sep 23, 2018
  9. Neerajrocks
    Eclair Sep 23, 2018
    i have updated from same.method but i am facing no such issue kindly tell me exactly what scenario are you facing?
    Vladut123 and dhaval24 like this.
  10. HUYNHNGUYEN
    Eclair Sep 23, 2018
  11. Neerajrocks
    Eclair Sep 23, 2018
    Yes its Stagged roll out so you might get it in sometime...
  12. HUYNHNGUYEN
    Eclair Sep 23, 2018
    HUYNHNGUYEN , Sep 23, 2018 :
    Plz let me update OS 9
    I had do you ask , Oneplusssssss
  13. rishabhjani
    Cupcake Sep 23, 2018
    Vladut123 and HUYNHNGUYEN like this.
  14. S1533735916536
    Donut Sep 23, 2018
    Hi.
    Do you have downgraded your device from oenbeta 3 to stable oxygen os
  15. dhaval24
    Froyo Sep 23, 2018
    means in oreo i use to less brightness n in dis i hv to use almost 50% brightness...apart from al al r fine well
  16. ade0410
    Ice Cream Sandwich Sep 23, 2018
    ade0410 , Sep 23, 2018 :
    no it's not.
    then don't use it then.
    wait for ota from OnePlus.
    simple as that.
  17. Neerajrocks
    Eclair Sep 23, 2018
    Thanks for description but i am not facing any such issue just wait for next ota update i am sure oneplus will release small patch updates to fix stuff like this after hearing feedbacks
  18. 8484818184
    Eclair Sep 23, 2018
    8484818184 , Sep 23, 2018 :
    I just updated my OP6 to Andriod P through Oxygen updater
    I am unable to see the update log !
    Can anyone tell me is it safe to update through Oxygen Updater
  19. dhaval24
    Froyo Sep 23, 2018
    Vladut123 and Neerajrocks like this.
  20. F1527454134703
    Donut Sep 23, 2018
