1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. Kytharsis
    Marshmallow Sep 24, 2018
    Kytharsis , Sep 24, 2018 :
    This is stable. If it were a beta, it'd be called "Beta 4", not "OxygenOS 9.0".
    Vladut123 likes this.
  2. wongsam8
    Cupcake Sep 24, 2018
  3. uditm
    uditm , Sep 24, 2018 :
    It's Butter smooth. Love the update. Cookie points to oneplus for the speedy release
    Vladut123, B_Wrath and Kytharsis like this.
  4. Kytharsis
    Nobody knows. If you're that impatient, download Oxygen Updater from the Play Store and download it manually.
  5. Aeron.yvs
  6. Ankur_Jaiswal
    Froyo Sep 24, 2018
    Ankur_Jaiswal , Sep 24, 2018 :
    For me, it is absolutely fine. You can try this step to troubleshoot.
    1. Remove the face data and re-register in a adequate light environment.
    Vladut123 and Arjun_de like this.
  7. Kytharsis
    Alright. Now you have two options: wait for your phone to get the update via OTA or use an app called Oxygen Updater to manually download/flash the update. It's safe, don't worry.
  8. mmahes
    Donut Sep 24, 2018
    mmahes , Sep 24, 2018 :
    the above message shows after following those steps.
  9. imsushantjain
    Froyo Sep 24, 2018
    imsushantjain , Sep 24, 2018 :
    Great work done guys, will be waiting for the same for OnePlus 3/3T :)
  10. Jaishetty007
    Gingerbread Sep 24, 2018
  11. MJ_Vikram
    KitKat Sep 24, 2018
    MJ_Vikram , Sep 24, 2018 :
    check if you have downloaded the correct package or not..
  12. mmahes
    Donut Sep 24, 2018
    downloaded the OOS 5.1.11
  13. Desai_Jay
    Froyo Sep 24, 2018
    Desai_Jay , Sep 24, 2018 :
    when will the incremental roll out be reached to all OnePlus 6, i mean is there any deadlines, that before this date all dev should receive OTA???
    wanna know, because I haven't received OTA update yet. Please advise.
    Thanks in advance.
    [e]1f609[/e][e]1f609[/e]
  14. MJ_Vikram
    KitKat Sep 24, 2018
  15. Z1534353228932
  16. Solarisirc
    Solarisirc , Sep 24, 2018 :
    really great so far, the only issue I see is that some times the multitasking previews appear blank.
    if I open the app and wait for a second the the preview appears correctly.
  17. MJ_Vikram
    KitKat Sep 24, 2018
    Oneplus will never give dates mostly it will take 2 weeks to reach all, you can use oxygen updater app if you can not wait..
    Desai_Jay and Vladut123 like this.
  18. sagar861996
    Donut Sep 24, 2018
  19. Aeron.yvs
    Aeron.yvs , Sep 24, 2018 :
    Thanks Kytharsis. BTW, how long should it take for my phone to get to date via OTA?
  20. Y1535260882728
    smns.srinivas and Vladut123 like this.
