1290
OxygenOS 9.0 OTA for the OnePlus 6
  1. prince2k85
    Froyo Sep 26, 2018
    prince2k85 , Sep 26, 2018 :
    check it manually
  2. NikhilVellara
    Cupcake Sep 26, 2018
    NikhilVellara , Sep 26, 2018 :
    isn't it because of the oxygen os update ?
  3. Artemus.
    Nougat Sep 26, 2018
    Artemus. , Sep 26, 2018 :
    No. That's how it is in Pie normally. Look at the Pixel, similar UI.
  4. NikhilVellara
    oh okay . I'm not a fan of this :/
  5. Artemus.
    Nougat Sep 26, 2018
    You'll get used to it eventually. Material Design 2 at its best.
    Deactivated User likes this.
  6. NikhilVellara
    I liked the UI before the update . hope I grows on me
    Artemus. likes this.
  7. tvgowthaman
    Donut Sep 26, 2018
  8. camohan
    Marshmallow Moderator Sep 26, 2018
    camohan , Sep 26, 2018 :
    The problem is no one reads the existing comments and wants to create his or her own thread. You should try some basic troubleshooting options like clearing and re-adding the fps and face unlock. It solves most of the problem.
    Plus if you read the first post of main thread you will realise where people are reporting issues. You can anytime go in ther and check others threads of they have reported similar.
  9. U1531422096579
    Donut Sep 26, 2018
  10. Govindarajan_Srinivasan
    Froyo Sep 26, 2018
  11. AmitExpectations
    Gingerbread Sep 26, 2018
    AmitExpectations , Sep 26, 2018 :
    just stop looking for a day u will get the update next day
  12. Saurabhshukal149
    Donut Sep 26, 2018
    Saurabhshukal149 , Sep 26, 2018 :
    no wifi during sleep option is not there..
    In location option is not there.
    1. High accuracy
    2.Battery saving
    3. Device only
    GPS is killing my battery.
    Battery draining faster.
    vanyaindigo likes this.
  13. Artemus.
    Nougat Sep 26, 2018
    A watched pot never boils. Stop obsessing about getting the update, it'll come to your device eventually.
  14. M1531153391564
    M1531153391564 , Sep 26, 2018 :
    I have a complaint that while using Screen Off Gesture there is no security of my data as there is no password and face unlock works. Simply by just drawing particular gesture anyone can unlock my phone and have full access of it.
  15. skpaul89
    skpaul89 , Sep 26, 2018 :
    Do you think I didn't searched about the problem, I did, but didn't found any thread about that. That's why I started that thread. I don't have time to be famous in this community or something like that, if I get my answer then I don't care whoever started which thread or what. If anything there where I can contribute and I am having enough time I might help someone but I don't think Generalized thread like this is going to help easily. If anyone isn't find something easily then what's the reason be here.
  16. horvath.patrick
    Honeycomb Sep 26, 2018
    horvath.patrick , Sep 26, 2018 :
    GPS has only 2 switches is by design so, directly from Google.
    and wifi and everything else will turn off over night.
  17. N1527187062422
  18. Telmooh
    Telmooh , Sep 26, 2018 :
    Ola OnePlus
    I just got the update and just a small touch of feedback; there is no logo for Bluetooth on the notification bar.
    Any possibility or getting this added?
    Thanks
  19. AmitExpectations
    factory reset option is the only way...
  20. N1527187062422
    N1527187062422 , Sep 26, 2018 :
    it will delete all my files, [e]1f614[/e]
