1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. tasos4606
    Donut Sep 26, 2018
    tasos4606 , Sep 26, 2018 :
    Just upgraded to Android 9...
    My first impression is the phone (OP6) seems faster! I will come back for more later on...
  2. A1537948791411
    Cupcake Sep 26, 2018
  3. santi358
    santi358 , Sep 26, 2018 :
    Silent mode does not work when the application is open. I saw it on WhatsApp.
  4. Atiq1989
    Froyo Sep 26, 2018
    Atiq1989 , Sep 26, 2018 :
    setting >button & gestures >quick gestures > enable double tap to wake
  5. apoorvadonthi
    Froyo Sep 26, 2018
    apoorvadonthi , Sep 26, 2018 :
    very bad update. screen is not at all bright even at 50% which was not the case in old version
    U1533623438076 likes this.
  6. orgesi
    Gingerbread Sep 26, 2018
  7. PriyankaHankare
    PriyankaHankare , Sep 26, 2018 :
    it's reaching to people! the UI is superb! not a lot has changed but it's relieving to know that there's more than limited accent Colors
  8. orgesi
    orgesi , Sep 26, 2018 :
    evrything is AMAZING with the new update! the best thing of it?! Battery !!! yes take a look, i charged my phone 11 hours ago and still i have 66% power left!
    before thr update at this point i would be eith like 20-30 % left
    Deactivated User and fidus62 like this.
  9. vivekdugar25
    Donut Sep 26, 2018
  10. H1536781577934
    H1536781577934 , Sep 26, 2018 :
    same problem here, full brightness now is the middle brightness I had before the update. fix it please?
  11. fidus62
    Jelly Bean Sep 26, 2018
    fidus62 , Sep 26, 2018 :
    That’s a real bullshit...
  12. D1537647101641
  13. apoorvadonthi
    Froyo Sep 26, 2018
    if you are happy about it.. its a shame.!! this will be a big problem in daylight outside conditions..
  14. Rake1441
    Rake1441 , Sep 26, 2018 :
    I find 2 major bugs
    1. navigation tool under pill option is not working properly and its crashing. I cannot use recent page option be either sliding the pill to left or right.
    2. when I move from one app to another by multitasking the app relaunches itself as though it's opening for the first time. e.g if I watch a video on YouTube and go to a WhatsApp chat and comeback to YT by way of multitasking the video should resume, instead it goes to homepage of YT
  15. Fr3lncr
    Froyo Sep 26, 2018
    Fr3lncr , Sep 26, 2018 :
    Received the official update today (Canada) installed it, and then the trouble started. Apps wont update in Google Play (they download and sit at 100% but don't install), and for some reason sent emails aren't showing up in my sent folder in my email app (BB Hub). The latter could be a compatibility issue but not sure what is causing the Google Play issue.
    I've rebooted, wiped cache in recovery, wiped cache for the Play Store app, but the issues persist.
    I'm not keen on doing a factory reset just to find out the problems will persist so I guess I'll wipe and reinstall Oreo and wait for Android 9.0.1 or whatever it will be.
    There goes loosing a day to a bad update.
  16. TCHB
  17. immkr007
  18. RbnW01
    RbnW01 , Sep 26, 2018 :
    Hey OnePlus,
    Please add the Feature of "swiping" between Apps if you using the Gestures[e]1f64f[/e]
  19. mohdazahar786
    mohdazahar786 , Sep 26, 2018 :
    after installing Android P.
    i am facing again and again launcher problem. phone properly hang.
    any body have any solution??????
  20. U1533623438076
    U1533623438076 , Sep 26, 2018 :
    I realized that the brightness isn't the same as before the update. I have to put in max level wich I only used to do in sunlight day. Now I'm using max brightness inside my home. I update last night. That's not good
