1289
OxygenOS 9.0 OTA for the OnePlus 6
  1. g_castorina
    Eclair Sep 26, 2018
  2. Drsamj
    Froyo Sep 26, 2018
  3. Kytharsis
    Marshmallow Sep 26, 2018
    Kytharsis , Sep 26, 2018 :
    You can use if if you like.
  4. Donwilly
    Gingerbread Sep 26, 2018
    Donwilly , Sep 26, 2018 :
    Search from the beginning of the thread.Guidelines are provided.
  5. Drsamj
    Froyo Sep 26, 2018
    Drsamj , Sep 26, 2018 :
    there were so many posts i cant read them all. my question is i downgraded from beta 3 nd unable to get regular update so is it safe .. will i get ota later on .. all features will work correctly?
  6. Kytharsis
    Everything will work fine. It's the exact same ROM as if you'd get it from an OTA.
  7. Drsamj
    Froyo Sep 26, 2018
    thanks bro
  8. P1538000845053
    Cupcake Sep 26, 2018
  9. Sumeetdhurmekar
    Froyo Sep 26, 2018
    Sumeetdhurmekar , Sep 26, 2018 :
    my system update not prompt update download so I was download the update from ota link so I was to downgrade to previous version.
    please help me anyone.
  10. Kytharsis
    Wait... what're you asking?
    EckoZ04 likes this.
  11. Sumeetdhurmekar
    Froyo Sep 26, 2018
  12. Kytharsis
    What're you trying to do? Revert to stable from beta or downgrade back to Oreo from stable Pie...?
  13. E1533399462584
    Eclair Sep 26, 2018
    sgmtnbike likes this.
  14. Sumeetdhurmekar
    Froyo Sep 26, 2018
    but I was think this is not stable version because there is so much issues in this version
  15. UnicornKaz
    Ice Cream Sandwich Sep 26, 2018
    UnicornKaz , Sep 26, 2018 :
    Why don't you tell us ? !!! ....It was you that he quoted !! :confused:o_O:rolleyes:
    gubro likes this.
  16. Kytharsis
    Like what?
  17. Light54
    Froyo Sep 26, 2018
    Light54 , Sep 26, 2018 :
    I'm extremely satisfied with this update. Had to let you know that.
    Great improvements, some that may take a little time to get used to, but that make the OnePlus experience as pleasant as it could ever be.
    Thank you a lot people!
  18. Pappilon
    Cupcake Sep 27, 2018
    Pappilon , Sep 27, 2018 :
    I thinks the mods kinda like it.. or why bother!
  19. Linxx
    Froyo Sep 27, 2018
    Linxx , Sep 27, 2018 :
    Hello @Manu J. my feeback on the update is as follows:
    Great job by the team to crank out the P update as quickly as they did.
    The little details like the running lines animation in the placeholder for photo-less contacts is a very nice touch...awesome :)
    I can see it was a mad rush though, and rightfully so. Respectfully, there seems to have been a slight oversight on the organization/layout/design of the beloved Shelf. Specifically the new Shelf's "Dashboard", as there are two lines that appear at the top and bottom of the data info box whenever you reduce the size of that individual component inside the Shelf. The title "Dashboard" also appears twice (one directly below the other) in the Shelf. The Shelf's Widget components also now appear inside a bounded box for some reason...? It looks fairly awkward, particularly with the "colored" and "white" themes enabled.
    Also, with the "dark" theme enabled the Notification Shade has a dark gray colour instead of the expected black colour.
    The corners of the "hide notch" feature's black bar is still not symmetrical with the corners of the permanent black bar at the bottom
    I'm positive (hoping) that these oversights will be tidied up n the next iteration of this OS version. Take a breather, ya'll deserve it. Keep up the awesome job.
    Kytharsis likes this.
  20. iamdrino
